SG350 global mode settings
Lukasz1977
Hi all,
Need to achieve L2 layer communication for some Dante devices and my connected PC which are on the same subnet but in different VLANs
I attached my plaintext so would like to ask you if possible to investigate where I did mistake. I think it is imposible to do in trunk mode but in general mode is achievable.
So the issue is as follows.
  1. My PC connected in port1 , natively VLAN1 with its IP addresse 192.168.1.7/24
  2. My Dante device with it IP address 192.168.1.33/24 connected to port2 natively VLAN1
  3. Created VLAN2 as Control Vlan for my PC and othes VLANs for my devices. All have the same subnet as I wrote above
  4. Used General Mode with its options to se tagged/untagged ports and have communication between VLANs but it failed.
I attached also my print screens how I set up my Vlans and ports....and my hole running config.
Wolud like to get some feedback if possible how to do to be worked as I want...
Thnaks.
0 Replies 0
