01-23-2021 01:23 PM
Hi All, I am a beginner here and looking for some help with intervlan routing using an SG320-10.
I updated the switch to the latest firmware (2.5.5.47) and started with default configuration.
I followed Cisco's video here (I only changed the vlan numbers and IPs slightly). The configuration from this video is just does not work.
https://www.youtube.com/watch?v=xK5HmMlaIlg
Here is my config:
PC1 >>> SG350 <<< PC2 (that's it, nothing else)
VLAN1: IP: 192.168.1.1/24 Ports 1,2,6,7,8,9
VLAN2: IP: 192.168.2.1/24 Ports 3,4
VLAN3: IP:192.168.3.1/24 Ports 5,10
VLAN2 DHCP Pool: 192.168.2.100 - 200 /24 Default Gateway (auto - gives out 192.168.2.1)
VLAN3 DHCP Pool: 192.168.3.100 - 200 /24 Default Gateway (auto - gives out 192.168.3.1)
Here are the results:
Connect PC1 to Port3 (VLAN2) - PC gets IP thru DHCP - 192.168.2.100 255.255.255.0 Default Gateway 192.168.2.1
Connect PC2 to Port5 (VLAN3) - PC gets IP thru DHCP - 192.168.3.100 255.255.255.0 Default Gateway 192.168.3.1
PC1 Ping Test (192.168.2.100)
>Ping 192.168.2.1 - Success.
>Ping 192.168.3.1 - Success. (seems to be across vlans, right?)
>Ping 192.168.3.100 - Request Time Out
PC2 Ping Test (192.168.3.100)
>Ping 192.168.2.100 - Request Timed Out.
Move PCs to same VLAN.
Move PC1 to port10(VLAN3) - PC gets IP thru DHCP - 192.168.3.101 255.255.255.0 Default Gateway 192.168.3.1
PC1 Ping Test Again (now 192.168.3.101)
Ping 192.168.2.1 - Request timed out. (Why? Because once there are no hosts remaining on VLAN2, the VLAN interface status changes to down. OK, that makes sense, sort of.)
Ping 192.168.3.100 - Success (Yep, so my PCs can ping each other - no firewall problems, unless is it possible that the firewall is blocking ICMP messages from different networks? I dont think so. That would be a first for me.)
Any help is appreciated!
Solved! Go to Solution.
01-23-2021 01:29 PM
If you were able to ping other VLAN Interface Looks Layer 3 routing working high level.
what kind of these devices windows PC, then Windows has default Firewall enabled, disable both the side and test and advise - before we dig deep in to other issues and solutions.
01-23-2021 01:29 PM
01-24-2021 05:38 AM
Yes, Sir. You are correct. The issue was Windows firewalls. Once I turned off the firewalls, the PCs could ping each other.
I am surprised by this. I thought I was verifying the firewall was not blocking ICMP messages by testing ping on the same VLAN, but obviously there was an issue across the networks.
