Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2950 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4539 Views
  • 1 replies
  • 16 Helpful votes
I inherited this device, did a factory reset and logged in to see what revision it is: - Firmware Version: 1.3.0.62 - Boot Version: 1.1.0.6 Pretty outdated! I read in the release notes and other forum topics that I should update the boot loader and f...
rcooke by Level 1
  • 4454 Views
  • 3 replies
Hello,I just try to create a new Vlan :- Number = 10-Name = secretariatBoth fields underneath are ticked, but VLAN stays déactivated !Switch : Cisco 200 Series Switches for Small Business 18 Ports, connected behind my router Synology RT1900ac.Solutio...
Tyyeul by Level 1
  • 659 Views
  • 1 replies
I'm trying to add a newly created VLAN to an existing trunk port.Logging into the web GUI, I go to CONFIGURATION / PHYSICAL INTERFACESI then click on port and get a pop up window called Ethernet Interface SettingsThen Port Settings tabHere's what I s...
danmand by Level 1
  • 1989 Views
  • 5 replies
I've been struggling to configure a range of ports on the SG350-10MP switch to be forced to static 15-watt PoE.It seems that the CLI reference on the Cisco website for the SG350-10MP doesn't match up with the actual PoE CLI commands. Can someone plea...
Hello,My have a PoE issus (not with a C3560CX), I have contacted TAC and they don't find SN in Data Base. They told me to contact my reseler but it is Cisco. No way to see!What can I do?Many thanks to your help.Regards
a_66 by Level 1
  • 1188 Views
  • 8 replies
I am using Singtel fibre optical broadband server. I installed a SG200-08 to untag the VLAN to port  2 and connect the port to RV042G WAN 1 port. it works fine with a public IP. Internet access is fine from router LAN ports.However, I try to ping the...
jiangqian by Level 1
  • 2511 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
