SG350X 100% CPU Utilization
MartinStuka
In the network we use Cisco SG350X-24-K9 V02 switches (FW: 2.5.0.90). After 495 days they rebooted spontaneously, or their uptime was reset, but there is no mention of the reboot in the log (and also no interruption of data). After about 3 weeks, the first of the switches started showing 100% CPU utilization. The change occurred in leaps and bounds from about 3-5% to 100%. I read data from the switches via SNMP, but even disabling this service did not reduce the CPU utilization. The switch has 6 active ports. Data flow is about 4Mbps. No routing. After a week or so, the same situation repeated itself on next switch. These are in a stack of 4 and again the processor has been running at 100% since then. I would like to find a way to find out what the CPU is utilizing and could prevent these conditions.
PS: The great thing about these SG350X switches is that even with 100% CPU utilization, the CLI and web interface are still available. With the SG500, we could also get the CPU to 100% utilization, but in addition, it was no longer possible to connect via telnet or the web, and when the device was disconnected from the port, the device would not reconnect.
balaji.bandi
not sure if this fix the issue.
1. as per the community most users having issue with SNMP - so disable SNMP and test it.
2. check any new Firmward available to update to fix the issue.
BB
Hi Balaji, thank you for your time.
I tryed to turn off SNMP (as I wrote it above) and it has no effect.
I am going to try new firmware, but I am a bit sceptic, because these problems last for long time (SG500 and now SG350X)
Make sure you take the backups config before upgrade.
BB
