05-06-2019 02:46 AM
Hello Community, this is my first post here and I hope to get an answer for a really weird behaviour.
We have a SG350XG-24F switch and attached to it a few HP ProLiant Server. NICs on HP servers are also with SFP+ slots. NICs are connected to SG350XG via Direct Attached Cable (DAC). On Ports 23 and 24 are optical transceivers connected and configured as trunk port. Via trunk port the switch is connected to other switches on other locations. Also the firewall is reachable via those trunk ports.
Now the issue. I got a new DAC cable with same specification like the other existing cables. It is just a little bit shorter. We have 5m cables and the new one is 3m. When I replace the existing and running cable with the new one on Port 11, my trunk ports on 23 and 24 go down because they change the media type from fiber to copper which is not working because it is fiber.
I have no idea why port 11 affects my trunk ports. Here a part of the log:
2147462699 2019-May-03 11:36:41 Informational %LINK-I-CHNGCOMBOMEDIA: Media changed from copper media to fiber media on port te1/0/24.
2147462700 2019-May-03 11:36:41 Warning %STP-W-PORTSTATUS: te1/0/23: STP status Forwarding
2147462701 2019-May-03 11:36:40 Informational %LINK-I-CHNGCOMBOMEDIA: Media changed from copper media to fiber media on port te1/0/23.
2147462702 2019-May-03 11:36:40 Informational %LINK-I-Up: te1/0/14
2147462703 2019-May-03 11:36:40 Warning %LINK-W-Down: te1/0/14
2147462704 2019-May-03 11:36:40 Informational %LINK-I-Up: te1/0/24
2147462705 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 310
2147462706 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 250
2147462707 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 240
2147462708 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 180
2147462709 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 170
2147462710 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 150
2147462711 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 145
2147462712 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 130
2147462713 2019-May-03 11:36:40 Informational %LINK-I-Up: Vlan 1
2147462714 2019-May-03 11:36:40 Informational %LINK-I-Up: te1/0/23
2147462715 2019-May-03 11:36:38 Informational %NSFP-I-SFPGibicRemoved: te1/0/11 SFP port is not present
2147462716 2019-May-03 11:36:38 Warning %LINK-W-Down: Vlan 310
2147462717 2019-May-03 11:36:38 Warning %LINK-W-Down: Vlan 250
2147462718 2019-May-03 11:36:38 Warning %LINK-W-Down: Vlan 170
2147462719 2019-May-03 11:36:38 Warning %LINK-W-Down: Vlan 150
2147462720 2019-May-03 11:36:38 Warning %LINK-W-Down: te1/0/11
2147462722 2019-May-03 11:35:37 Warning %LINK-W-Down: Vlan 240
2147462723 2019-May-03 11:35:37 Warning %LINK-W-Down: Vlan 180
2147462724 2019-May-03 11:35:37 Warning %LINK-W-Down: Vlan 145
2147462725 2019-May-03 11:35:37 Warning %LINK-W-Down: Vlan 130
2147462726 2019-May-03 11:35:37 Warning %LINK-W-Down: Vlan 1
2147462727 2019-May-03 11:35:37 Warning %LINK-W-Down: te1/0/24
2147462728 2019-May-03 11:35:35 Informational %LINK-I-CHNGCOMBOMEDIA: Media changed from fiber media to copper media on port te1/0/24.
2147462730 2019-May-03 11:35:16 Warning %LINK-W-Down: te1/0/23
2147462731 2019-May-03 11:35:15 Informational %LINK-I-CHNGCOMBOMEDIA: Media changed from fiber media to copper media on port te1/0/23.
2147462735 2019-May-03 11:29:14 Warning %STP-W-PORTSTATUS: te1/0/11: STP status Forwarding
2147462736 2019-May-03 11:29:10 Informational %LINK-I-Up: te1/0/11
2147462737 2019-May-03 11:29:10 Informational %NSFP-I-SFPGibicDetected: te1/0/11 SFP port is present
You can see when I plug in the DAC on Port 11 the media type on port 23 and 24 change and all VLANs go down. When I unplug the port 11 media type changes back and all is working.
Any ideas? Why can a cable attached to one port affect a total different port?
Thanks for your suggestions.
Andreas
05-06-2019 04:02 AM
can you post the config ?
05-06-2019 04:32 AM
------------------ show running-config ------------------
config-file-header
SWSRV2WHT23
v2.2.0.63 / RTESLA2.2_810_156_020
CLI v1.0
file SSD indicator excluded
unit-type-control-start
unit-type unit 1 network te uplink none
unit-type unit 2 network te uplink none
unit-type unit 3 network te uplink none
unit-type unit 4 network te uplink none
unit-type-control-end
vlan database
vlan 130,140,145,150,170,180,240,250,310
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 192.168.140.10
ip dhcp relay enable
ip dhcp information option
bonjour interface range oob
hostname "hidden"
line console
exec-timeout 5
exit
line ssh
exec-timeout 5
exit
line telnet
exec-timeout 5
exit
line console
no autobaud
exit
management access-list QAM
permit
exit
management access-class QAM
no passwords complexity enable
passwords aging 0
username admin password encrypted "hidden" privilege 15
ip ssh server
ip ssh password-auth
snmp-server server
snmp-server location "WHT 23. OG"
snmp-server contact ITSYSTEMS
no snmp-server trap authentication
snmp-server filter System system included
snmp-server filter Interfaces interfaces included
snmp-server community QAMGMBH ro view Default
snmp-server community QAMGMBH ro "hidden" view Default
snmp-server host "hidden" informs version 2c QAMGMBH
snmp-server group "hidden" v2
ip http timeout-policy 300
no ip http server
clock timezone " " +1
clock summer-time web recurring eu
sntp server "hidden" poll
ip domain name "hidden"
ip name-server "hidden"
ip domain polling-interval 18
security-suite enable global-rules-only
security-suite dos protect add stacheldraht
security-suite dos protect add invasor-trojan
security-suite dos protect add back-orifice-trojan
interface vlan 130
name ffm_clt
interface vlan 140
name ffm_srv
interface vlan 145
name ffm_test
interface vlan 150
name ffm_dmz
interface vlan 170
name ffm_dmz_ext_router
interface vlan 180
name ffm_sw_dmz_mgmt
ip address "hidden"
interface vlan 240
name esh_srv
interface vlan 250
name esh_dmz
interface vlan 310
name ffm_exchange
interface TengigabitEthernet1/0/1
spanning-tree link-type point-to-point
macro description switch
interface TengigabitEthernet1/0/2
interface TengigabitEthernet1/0/4
interface TengigabitEthernet1/0/5
description "zu VMESXi-3 Port 1"
switchport access vlan 140
interface TengigabitEthernet1/0/6
description "zu VMESXi-4 Port 2"
interface TengigabitEthernet1/0/7
description "zu VMESXi-10 Port 1"
switchport mode trunk
switchport trunk allowed vlan remove 1-139,141-144,146-4094
interface TengigabitEthernet1/0/8
description "zu VMESXi-10 Port 2"
switchport trunk allowed vlan remove 1-129,131-4094
interface TengigabitEthernet1/0/9
description "zu VMESXi-20 Port 1"
interface TengigabitEthernet1/0/10
description "zu VMESXi-20 Port 2"
interface TengigabitEthernet1/0/11
description "zu VMESXi-6 Port 2"
switchport trunk allowed vlan remove 1-149,151-169,171-249,251-309
switchport trunk allowed vlan remove 311-4094
interface TengigabitEthernet1/0/12
description "zu VMESXi-13 Port 1"
interface TengigabitEthernet1/0/13
description "zu VMESXi-18 Port 1"
interface TengigabitEthernet1/0/14
speed 1000
description "zu VMESXi-22 Port 2"
interface TengigabitEthernet1/0/21
interface TengigabitEthernet1/0/22
interface TengigabitEthernet1/0/23
description "*** zu SWSRV2WHT22 Port 23 ***"
!next command is internal.
macro auto smartport dynamic_type switch
interface TengigabitEthernet1/0/24
description "*** zu SW2WHT22 Port 23 ***"
macro description "switch "
exit
ip dhcp snooping
ip dhcp snooping information option allowed-untrusted
ip default-gateway "hidden"
------------------ show interfaces configuration ------------------
Flow Admin Back Mdix
Port Type Duplex Speed Neg control State Pressure Mode
te1/0/1 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/2 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/3 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/4 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/5 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/6 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/7 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/8 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/9 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/10 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/11 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/12 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/13 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/14 10G-Fiber Full 1000 Disabled Off Up Disabled Off
te1/0/15 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/16 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/17 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/18 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/19 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/20 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/21 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/22 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/23 10G-Combo-F Full 10000 Enabled Off Up Disabled Auto
te1/0/24 10G-Combo-F Full 10000 Enabled Off Up Disabled Auto
Flow Admin
Ch Type Speed Neg control State
Po1 -- -- Enabled Off Up
Po2 -- -- Enabled Off Up
Po3 -- -- Enabled Off Up
Po4 -- -- Enabled Off Up
Po5 -- -- Enabled Off Up
Po6 -- -- Enabled Off Up
Po7 -- -- Enabled Off Up
Po8 -- -- Enabled Off Up
Admin
Oob Type Duplex Speed Neg State
oob 1G-Copper Full 1000 Enabled Up
------------------ show interfaces status ------------------
Flow Link Back Mdix
Port Type Duplex Speed Neg ctrl State Pressure Mode
te1/0/1 10G-Fiber -- -- -- -- Down -- --
te1/0/2 10G-Fiber -- -- -- -- Down -- --
te1/0/3 10G-Fiber -- -- -- -- Down -- --
te1/0/4 10G-Fiber -- -- -- -- Down -- --
te1/0/12 10G-Fiber -- -- -- -- Down -- --
te1/0/15 10G-Fiber -- -- -- -- Down -- --
te1/0/16 10G-Fiber -- -- -- -- Down -- --
te1/0/17 10G-Fiber -- -- -- -- Down -- --
te1/0/18 10G-Fiber -- -- -- -- Down -- --
te1/0/19 10G-Fiber -- -- -- -- Down -- --
te1/0/20 10G-Fiber -- -- -- -- Down -- --
te1/0/21 10G-Fiber -- -- -- -- Down -- --
te1/0/22 10G-Fiber -- -- -- -- Down -- --
te1/0/23 10G-Combo-F Full 10000 Enabled Off Up Disabled Off
te1/0/24 10G-Combo-F Full 10000 Enabled Off Up Disabled Off
Flow Link
Ch Type Duplex Speed Neg control State
Po1 -- -- -- -- -- Not Present
Po2 -- -- -- -- -- Not Present
Po3 -- -- -- -- -- Not Present
Po4 -- -- -- -- -- Not Present
Po5 -- -- -- -- -- Not Present
Po6 -- -- -- -- -- Not Present
Po7 -- -- -- -- -- Not Present
Po8 -- -- -- -- -- Not Present
Link
oob 1G-Copper -- -- -- Down
------------------ show interfaces port-channel ------------------
Load balancing: src-dst-mac.
Gathering information...
Channel Ports
Po1
Po2
Po3
Po4
Po5
Po6
Po7
Po8
05-06-2019 05:08 AM
High level some STP loop i can see here
Can you please explain te1/0/23 te1/0/24 and 1/0/11 how they are connected ? do you have any network topology ?
