SG350XG upgrade questions
tato386
Level 6
Level 6
I have a 2 unit SG350XG stack that is currently running 2.3.5.63 firmware.  I have uploaded the 2.5.0.83 file but I noticed it has "signed" in the filename which the 2.3 does not.  Can I jump to this newer, signed version with a simple file swap and reboot or do I need to do something else?
Also, is there a way to reboot one stack member at a time?
Diego
mridsing
Thanks for your post.
Yes you can jump to latest one signed and swipe image, then reboot switch so that new firmware can be active.
As for switch doesn't have feature of individually rebooting switches in stack (Manual from GUI or CLI).
Thanks and regards,
Mridul
Cisco SBSC
mridsing
Thanks and regards,
Mridul
Cisco SBSC
Got it.
