08-07-2013 03:06 PM
I have been installing SG300 and SG500 switches and using the auto voice vlan feature by simply changing voice vlan to 100 and using vlan 1 for default and data. I normally put the switch in L3 mode and make an access porteach for my IP PBX (vlan 100) and one to connect to existing data network (vlan 1). Then I make a static route in customers default gateway to route back to vlan 100 and everything works nicely for most installs.
On my last install I decided to try to change the default vlan 1 to vlan 10 and go with 10 for data and 100 for voice. The problem I ran into was that the auto generated config on my phone switchports still use vlan 1 as native vlan. I am trying to find a way to still use auto vlan and get the desired native vlan without having to make manual config changes.
Should this be possible?
Thanks in advance.
Solved! Go to Solution.
08-07-2013 03:08 PM
Hi Brandon, you need to modify the macro from native vlan 1 to vlan 10.
Check out this topic how to modify the macro
https://supportforums.cisco.com/thread/2177613
-Tom
Please mark answered for helpful posts
08-07-2013 03:08 PM
-Tom
08-07-2013 03:43 PM
BINGO! thanks for the quick response.
