Bookmark
Subscribe
2338
SG500 showing the same MAC address on more than one port?
danielj80
My ISP has been helping me troubleshoot a problem we've been having with an interaction between our SG500 stack on their HP customer premises equipment.
I have the SG500 stack partitioned into two VLANS. 8 ports on VLAN11, and the rest on VLAN1. Both are native, untagged VLANs so they should only carry traffic for their own VLAN with no mixing. I also route between these VLANs on the stack.
VLAN11 switch ip: 10.76.20.20
VLAN1 switch ip: 10.1.1.1
I've taken a port from each VLAN, and plugged it into the ISP's HP switch, where there are matching separated VLANs which then connect to a remote datacenter through a MPLS.
Here's the issue: the SG500 seems to be presenting the base mac address on both ports of the ISP's HP switch. This confuses the HP switch, and I end up having packets drop into a black hole. This is the output from the HP switch showing the SG500 stack's base mac moving between ports within a few seconds:
HP# show mac-address 8843e1-af7085
Status and Counters - Address Table - 8843e1-af7085
  MAC Address : 8843e1-af7085
  Located on Port : 15
  Located on Port : 11
Any idea what is going on here? It's as if the SG500 is using the same MAC for both its IP addresses.
Thanks!
Tom Watts
Hi Dani, the only MAC address advertised by the SX300/500 series should be the system MAC. If you do show mac address-table on the SX500 you should see the same MAC for both VLAN. I do not know why this is confusing the HP switch unless it is not handling the tag vlan correctly between switches.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Tom,
Indeed, the HP switch was not indexing on MAC and VLAN properly. The ISP replaced the switch with a one from Juniper, and the problem went away.
Hi guys,
i am trying to find the IP add associated to mac on cisco sg500 switch port. i am performing these to
#sh mac address-table interface GigabitEthernet1/1
Aging time is 300 sec
Vlan Mac Address Port Type
1 34:64:a9:10:d6:16 gi1/1/1 dynamic
#sh arp mac-address 34:64:a9:10:d6:16
Total number of entries: 1
VLAN Interface IP address HW address status
There is no entry showing in it. Can anyone guide me
