SG500X-48-K9-G5 and SG200-18 compatible SFP
ngtransge
I am interesting if GLC-SX-MM sfp modules are compatible with following switches: SG500X-48-K9-G5 and SG200-18.
Do you have any information about it ?
7 Replies 7
Davidwagman1
Level 7
Level 7
It doesn't appear that the GLC-SX-MM is compatible with the SG500. I quoted the manual below so you can see the compatible SFPs for the two switches.
Best,
David
Please rate helpful posts.
From the SG500 manual:
The following FE SFP (100Mbps) transceivers are supported:
•          MFEBX1: 100BASE-BX-20U SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 20 km.
•          MFEFX1: 100BASE-FX SFP transceiver, for multimode fiber, 1310 nm wavelength, supports up to 2 km.
•          MFELX1: 100BASE-LX SFP transceiver, for single-mode fiber, 1310 nm wavelength, supports up to 10 km.
The following GE SFP (1000Mbps) transceivers are supported:
•          MGBBX1: 1000BASE-BX-20U SFP transceiver, for single-mode fiber, 1310 nm wavelength, supports up to 40 km.
Cisco 500 Series Stackable Managed Switch Administration Guide          93Managing Device Diagnostics          8
•          MGBLH1: 1000BASE-LH SFP transceiver, for single-mode fiber, 1310 nm wavelength, supports up to 40 km.
•          MGBLX1: 1000BASE-LX SFP transceiver, for single-mode fiber, 1310 nm wavelength, supports up to 10 km.
•          MGBSX1:1000BASE-SX SFP transceiver, for multimode fiber, 850 nm wavelength, supports up to 550 m.
•          MGBT1: 1000BASE-T SFP transceiver for category 5 copper wire, supports up to 100 m.
From the SG300 manual:
MSA-compatible SFPs
Cisco Small Business 300 1.1 Series Managed Switch Administration Guide          67Managing Device Diagnostics          7
Hello David,
Thank you for helping.
I know this data sheet. I am interesting if this GLC-SX-MM module is supported. Prior to these SG series switches cisco had ESW 500 series and they were support GLC-SX-MM sfp. But in supported sfp data sheet thay only had
MG and MF module.
It may work, but it is NOT supported.
Best,
David
If I use MGBSX1 SFP with OM3 cable will it work for 1 1000 meters ?
No, the MGBSX1 max distance is 500 meters.
Best,
David
The MGBSX1 is compatible with series SG500X ??
The series SG500X say only support .-
Cisco SFP+ optical modules that are supported in the 500X switches
are: SFP-10G-SR, SFP-10G-LRM, and SFP-10G-LR.
http://www.cisco.com/en/US/docs/switches/lan/csbms/Sx500/quick_start/500_Series_QSG.pdf
The SG500X say
4*10 Gigabit Ethernet SFP+ (2*10 GE+ 2*10GE/5GE-Stacking Combo)
Also suport 1GB module MGBSX1 ??
Hi Omar, you may use this SFP between the switches.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
