SG500X LACP issue
stgeorges
I'm having a strange issue with adding a port to a port channel on a SG500X (cab1). I have Port Channel 1 with Te1/1/1 as a member, I want to add Te2/1/1. These are connected to a Catalyst 6500 (Cat6500). However I get
cab1(config)#int TengigabitEthernet2/1/1
cab1(config-if)# channel-group 1 mode auto
Port te2/1/1 type differs from port-channel Po1 type.
I always get
Any pointers? I've 6 other of these swtiches (with the same firmware) and not seen this issue.
SG500X(cab1)
cab1#sh ver
       Unit             SW version         Boot version         HW version
         1               1.2.0.97            1.2.0.12               V01
         2               1.2.0.97            1.2.0.12               V01
cab1#sh run interface Port-Channel 1
interface Port-channel1
description SWITCHULINK
spanning-tree link-type point-to-point
macro description switch
switchport trunk allowed vlan add 2,39-41,43,46,50,60,167-169,300
!next command is internal.
macro auto smartport dynamic_type switch
cab1#sh run int po1
cab1#sh run int TengigabitEthernet1/1/1
interface tengigabitethernet1/1/1
description SWITCHUPLINK
cab1#sh run int TengigabitEthernet2/1/1
interface tengigabitethernet2/1/1
cab1#conf t
Cat6500 config
Cat6500#sh run interface po17
Building configuration...
Current configuration : 123 bytes
interface Port-channel17
description CAB1
switchport
switchport mode trunk
end
Cat6500#sh run interface gi
Cat6500#sh run interface gigabitEthernet 4/24
Current configuration : 158 bytes
interface GigabitEthernet4/24
description CAB1
switchport
channel-group 17 mode active
end
Cat6500#sh run interface gigabitEthernet 9/42
interface GigabitEthernet9/42
description CAB1
switchport
Cat6500#sh etherchannel 17 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Number of channel-groups in use: 20
Number of aggregators:           21
Group  Port-channel  Protocol    Ports
17     Po17(SU)        LACP      Gi4/24(P)      Gi9/42(I)
Last applied Hash Distribution Algorithm: Fixed
Tom Watts
Hi stgeorges, i'll first say I don't know the answer. However, the differences I do see is the macro has negotiated on the te1/1/1 which could be causing a 'difference' from the te2/1/1.
Can you delete the connection then use the interface range command to build the channel group? May also not be a bad idea to remove the physical connection or shut down the connection on the 6500 side.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
Thanks for your reply I neglected to say I've tried various combinations of shutting down the C6500 port, SG500 port etc. I've not tried "interface range" command you suggest so will give that a try.
When you say "delete the connection" do you mean the Port Channel? I've a small problem in that the swtich is "remote" and I can't risk loosing the connection ATM. I'll be able to get to it physically tomorrow when I'm back in the office.
One other thing I've just noticed is this
cab1#sh interfaces configuration TengigabitEthernet 1/1/1
                                               Flow    Admin     Back   Mdix
Port     Type         Duplex  Speed  Neg      control  State   Pressure Mode
te1/1/1  1G-Fiber     Full    10000  Enabled  Off      Up      Disabled Off
cab1#sh interfaces configuration TengigabitEthernet 2/1/1
te2/1/1  10G-Fiber    Full    10000   Disabled Off      Up      Disabled Off
Both of these **should** be 1G-Fiber. I'll check the SFP in the morning but I'm sure we ordered only 1G SFP's not 10G.
Not sure if this would cause it tho.
Well, when adding the channel group the 6500 is probably going to err-disable, there isn't an out of band management? If you're using 1 gig links I'm not sure why you're using the ten gig ports. But yeah, your 10 gig links are reporting 10g, what sfp did you order?
-Tom
Hi Tom,
No, no out of band management on these I'm afraid. Cheep(ish) and cheerful was the order of the day when providing this connectivity:-)
The SFP's we ordered are P/N MGBSX1.
We're using the TE ports since we need the distance, as AFAIK the SG500X has 2 x Stack ports and 2 x 1G/10G SFP ports for use in the defualt stacking mode. FYI we're using the default staching option from p10-11 of this, so they should support 1G or 10G
http://www.cisco.com/en/US/docs/switches/lan/csbms/Sx500/quick_start/500_Series_QSG.pdf
TE2/1/1 is definilty coming up a 10G optics for some reason so it could be we've either had a wrong SFP shipped or we've mistakenly plugged in an incompatible SFP which is confusing it.
Dan
