SNMP file MIB for slm2008
bferrell
Is anyone aware of a specific MIB for the SLM2008?
I'm looking to monitor them with devmon
mipopov
These switches does not have SNMP.
Hope it helps
Cheers,
Mike
Actually they do, but it has to be enabled
How you enable SNMP ? - can you attach a screenshot?
Thank you in advance
Cheers,
Mike
It doesn't show up on the web ui.
I found this link by searching for "slm2008 enable snmp":
https://ict-freak.nl/2011/04/10/how-to-enable-snmp-on-a-linksyscisco-slm2008-switch/
that shows how with an offboard perl script
You may see this twice because I'm going to re-post with just the search incase the link get's filtered
