memory upgrade
amralrazzaz
Level 5
Level 5
I need to ask about the availability to upgrade the memory of the below devices i have :
 1- have 2 Switches 24 PORTS CATALYST 2960 - X SERIES GigE PoE 370W 4 X 1G SFP LAN Base (WS-C2960X-24PS-L)  128 mb flash memory and 512 dram ( can i upgrade the memory of my switches ? if yes whats the maximum memory should i use ? also is it has free slots inside to install more memory?
2- C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1
512mb of ram -
255488K bytes of ATA System CompactFlash 0 (Read/Write)
255488K (256MB)
255K bytes of non-volatile configuration memory
whats the maximum mamory for upgrade ? and there is free slots or i should remove the current and install the new one?
amr alrazzaz
Look at the URL provided ealier post 2911 model you have RAM and Flash information.
BB
5 Replies 5
balaji.bandi
if the device Model C2960-X then that is maximum you have already.
refer the compare document :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/qa_c67-728348.pdf
BB
thanks alot so no upgrade for the switch i have ok perfect
what about the router that i have ? can i upgrade it ?
amr alrazzaz
Since you have mentioned only C2900 ( that is the model of product, you have not mentioned what is the full model, i can not suggest what can be done)
But you have this link which can give you the model can upgrade to max.
https://www.cisco.com/c/en/us/products/routers/2900-series-integrated-services-routers-isr/models-comparison.html
BB
hi sir thanks for ur reply
the model that i have is 2911 as below
isco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ190360AM
3 Gigabit Ethernet interfaces
1 terminal line
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
amr alrazzaz
BB
