SRW2048 unable to console in
VictorVEnciso
So I decided to purchase a SRW2048 for a switch and now that I have it the previous owner must of had changed up the port and web gui ip since i cannot console in
I use Hyper Terminal with these settings
Bits per second : 38400
Data bits: 8
Parity: None
Stop Bits : 1
Flow control : None
And I still get nothing
Right, you bought a null modem cable wich is common, but according to the thread I linked to you will need a straight cable to console into this switch.
-- please remember to rate and mark answered helpful posts --
6 Replies 6
Brandon Svec
Level 7
Level 7
Hi Victor, you probably need to find or make a different cable than you are used to.  See here:
http://community.linksys.com/t5/Switches/Console-cable/m-p/85004?query.id=92299
Yes, that look right to me.
Thank you very much!!!
That did the trick and now when I connect to console I can see everything! :)
Thanks.
/RESOLVED
