SRW248G4P management
CMBanktech
I have a SRW248G4P switch.  I would like to manage this switch.  I am sure this switch is not at factory defaults.  I have connected a laptop to the console port and the switch does not respond.  My settings are correct.  How can I reset this switch back to factory defaults?
Tom Watts
Hello Joe,
Unfortunately, the only way to reset the switch is via GUI or the console access. If the console is not accessible, you can call the SBSC and check the warranty status of the switch.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
Hello Joe,
Davidwagman1
Level 7
Level 7
Joe,
Did you check baud rate you were using? I'm drawing a blank and I'm away from the computer for a few days but maybe Tom can hop in - I think it's
38400,1,n,n.
Best,
David
Yes, I was at 38400,1,n,n.  The switch is out of warranty.  I will dispose of the switch.
Thanks for your response.
