Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2824 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4368 Views
  • 1 replies
  • 16 Helpful votes
We have recently purchased a SG300 to break up our network which most consists of virtual machines via Bridged networking on network machines. I have created successfully Vlans and the physical machines are capable of communicating across the differe...
Hello frends,I'm using switch at our IP camera security systems in below.SRW208MP-K9-EU(2 pieces)SRW224G4P-K9-EU(4 pieces)SLM2024PT-EU(1 piece)with Supermicro Server System and Cat6 cabling.All of them is poe switch.(I think, you know)I feed 36 IP ca...
Hello,I have purchased a Cisco SF 302-08P 8-port 10/100 PoE Managed Switch with the intention of creating VLAN's for my home network. The idea behind this set up is having 1 network for gaming and the other for work. I am thinking on having 2 separat...
maakri123 by Level 1
  • 4457 Views
  • 2 replies
I was given a linksys SRW224G4 switch .. It seems to work fine on some ports and others dont .. I am tring to log into it to see what the current config is .. but no luck .. I cant seem to find what ip address its pulling to be able to log into the w...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
