SVI support on SG 300 series switches
khurram1987
hi people:
my client have 6 sg 300 switches one switch is connected with firewall an d firewall has dhcp server of one network, they want to make another vlan of another network, if sg 300 series support SVI's than i can make two svi's on my one switch.i think they dont support svi other than default.can you help me out on this problem...
Tom Watts
Hi Khurram, the switch does support layer 3 vlan interfaces.
You may log in to the CLI and use the command
set system mode router
Once you do this, this will factory default reset the switch after reload.
Once the switch has come back up, ensure the first thing you do is make a static IP address on vlan 1 then proceed to make your additional vlans and ip addresses on the vlans
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Thanks Tom for your valuable words, it has helped me alot and problem solved once i did it to router mode.
thanks
