Switch inaccessable when I create an IP interface on SG500-28P
Boudewijn Plomp
I have a brand new SG500-28P sitting on my desk. I am having a very weird problem. I hope someone can advice me.
The swtich is configured and going to operate in L3 mode. All ports are still assigned to the default VLAN ID 1. I have created several new VLAN's. Once I configure and aplly an IP Interface to a certain VLAN the swtich becomes inaccessable right away. I am pretty sure I am not pulling my own VLAN under my connection. Every port is inaccessable. I have to pull the power plug and restart the swtich with its saved configuration. Even when I add another IP interface to the default VLAN 1, same issue. I have tried lot's of things, but can't get it to work properly. I have just upgraded to the latest firmware.
I have configured dozens of SG300 swtiches which is very easy. This one does not work with me.
Any suggestions?
Tom Watts
Hi, you need to assign a static IP to vlan 1 first.
config t
int vlan 1
ip address 192.168.1.254 /24
int vlan 2
ip address 192.168.2.254 /24
etc. This will resolve the problem.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
config t
int vlan 1
int vlan 2
-Tom
I just noticed that. VLAN ID already has the default IP interface 192.168.1.254. But I noticed that when you add another IP interface the IP interface for VLAN 1 is removed. I find that a bit strange.
But this will do. Thank you.
