Unable to create or remove VLAN
manojkumard
I'm unable to create or remove any VLAN on my cisco switch...
C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA6
Error:
APP-SW-LAN-CISCO-#5(config)#no vlan 10
Error on initialize VLAN database 1: VTP feature not yet initialized
when i give "show run".... im receiving below error...
LAN-CISCO-#5#sh run
Building configuration...
Wat is the cause.... any suggestion...
If you don't use VTP features try to add these command:
vtp domain CISCO
vtp mode transparent
Now you should be able to add and remove vlan.
Regards.
