Upgrade path from fimware Boot Version :1.3.5.06 & Firmware Version (Active Image): 1.4.2.4 to latest version 1.4.10.6
ram821993
Dear Team,
My Cisco switch SG300-52 52port Gigabit switch has Boot Version :1.3.5.06 & Firmware Version (Active Image): 1.4.2.4.
We are looking to upgrade to the latest version 1.4.10.6,
Please suggest on the upgrade path of this switch, can I directly upgrade to firmware 1.4.10.6 and do I need to upgrade the boot version
Shiva
balaji.bandi
here is the release notes for the upgrade 1.3,X  and 1.4.X
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/release_notes/R_1_4_10_6_RN.pdf
BB
You can have same boot file version. also you may be able to upgrade to 1.4.10.6 directly and in any case system will display error and you can try mid versions if needed.
Good luck
KB
