Using LAN Port 1 of RV340 for LAG
Hello and thanks for your help.
I have a Cisco RV340 and would like to create a LAG using LAN ports 1 and 2. However it seems like I am limited to only choosing ports 2-4. Currently my port configuration is at defaults (I have not changed anything) and this model does not seem to support SSH or serial access so do not think I can bypass the web GUI. If there is a way to do this please let me know, thanks.Screenshot 2021-02-11 171349.png
Sujoy Paria
Yes, LAN port 2 to 4 only can be part of LAG in RV340 Router.
The console port is being used for development and troubleshooting by Cisco support. It is also on there for future use. The RV340 router is designed to managed via the GUI and some APIs.
Sujoy Paria
Thank you very much for clarifying
