vlan routing on SG300-28P
edisoninfo
Setup:
                                   192.168.1.23
ASA5505    ------------     SG300-1    ------------   SG300-2    192.168.1.21
192.168.1.1                          |
                                            +---------------------   SG300-3    192.168.1.22
                                            +---------------------   SG300-4    192.168.1.24
                                            +____________   two Dell PowerConnect switches on 192.168.1.30 and .31    (Windows servers & computers)
SG300-1  is in layer 3 mode
     vlan1 (default)
     vlan100 (voice)
     vlan100 dhcp server on the 192.168.100.0 network
     Auto voice vlan set to 100
SG300-2,3,4 are all in layer 2 mode
Problem:
The phones plugged into SG300-4 have PC's plugged into them. The phones and pc's all fire up fine just like it is supposed to work. The phones all come up on 192.168.100.0 network and pc's are on the 192.168.1.0 network. Magic!!
The phones plugged into the SG300-1 switch all come up just fine on the .100 network. No pc's on this switch.
The phones plugged into the SG300-2 and -3 switches can not find an IP address. I can see in the binding list on the SG300-1 switch a bunch of "preallocated" addresses from the mac addresses of those phones but the phone just sits there waiting for an address.
It is as if the dhcp response from the phone never makes it back to SG300-1 to tell it has the address.
Why does SG300-4 work and the other two do not? I have compared configs until I am cross-eyed and swear they are identical.
edisoninfo
Hm, not even a hint?  OK, well I have it mostly working finally. I say mostly because all of the phones and pc's have now pulled the correct ip's from their proper subnets and and fine. The last issue is from a 192.168.1.x computer I can ping a 192.168.100.x computer but can not access anything on it. One is a web server and even tho I can ping it, does not respond. I did a port scan on it from the .1.x network and it shows all ports closed.
Why can I ping it fine but not access anything on it?
Gary
I suspect no one has helped because this forum deals with Cisco Catalyst switches so there is limited experience with the Small Business switches. There is a dedicated forum for these switches so you could move this thread there and you are far more likely to get help from people who work with these switches -
https://supportforums.cisco.com/community/netpro/small-business/switches?view=discussions
Jon
Thanks Jon.marshal. I have moved it as you suggested. When I posted I just did a search and guess I landed on the wrong list.
Hi Gary, that sounds more like a firewall/security software issue on whatever you're trying to access. If a ping works, it means the routing works.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
