VLAN support on ESW 500 switch
rachshah20
How many VLANs does the ESW 500 switch support?
Maulik Shah
Level 5
Level 5
The ESW 500 switch supports a max of 256 VLANs and can accomodate upto 8000 MAC addresses in the CAM table.
Note, by default on the POE switches, VLANs 1 (data) and 100 (voice) are enabled while on the non POE switches, only VLAN 1 (data) is enabled.
How many vlans id support?
Daniel.
All,
Can you confirm that Cisco ESW5xx supports up to 256 VLANs ?
Velin Tsekov
Hi Velin,
     As Maulik mentioned, the ESW500 series switches support up to 256 vlans.
