VoIP QoS on SGE2010p
750langlois
hello,
Need help to configure QoS on a SGE2010P.  It's for VoIP. I setup it's own vlan but doesn't seems to be the solution.
What is the best way to set it up? i already look at that document but i'm not sure what to do http://www.cisco.com/en/US/docs/switches/lan/csbms/sge2000/reference/guide/sge_refguide.pdf
Any advice is appreciate.
paolo bevilacqua
Wrong forum, post in "small business - switches". You can move your post using the actions panel on the right.
Take a look at this thread. The SGE2010p is slightly different, but the web ui should be relatively similar:
https://supportforums.cisco.com/message/3683639#3683639
Best,
David
Please rate helpful posts.
Hello David,
Nice post, but the SGE2010p seems to be a little different..   have a look at this and let me know what you think about it..
1st i set up the advanced mode here..
i create the policy table here;
ClassMap is a little bit different..
I can't select any because no ACL has been created..  but i do not know where to create ACL.
Any Idea?
After you add a Class Map, go into policy table. Are you able to add/edit the policy to include that class map?
Best,
David
