VPC Domain from peer-switch to peer-gateway
Fabio Perticone
Hallo There,
i have two NXS 3K series configured in VPC domain Peer-Switch
I want ask if i can switch from peer-switch to peer-gateway without lost vpc configuration.
Best Regards,
Fabio
each one have different function
peer-gateway effect SVI
peer-switch effect stp
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/nx-os-software/217274-understand-virtual-port-channel-vpc-en.html
thank you for your reply,
i have hsrp configured on my vlan's Virtual Interface, and i know that it would be better have peer-gateway configured,
i want to know if i can change the vpc domain configuration from peer-switch to peer-gateway without lost vpc portchannel configuration?
Best Regards,
Fabio
