Warning %STP-W-PORTSTATUS: gi1: STP status Forwarding
eddieyip8
In my SG200-50 switch, there are a lot of warning message about STP status Forwarding.  Warning messages shown as below when I use a new SG200-18 switch with only one PC connected.  Please advice and many thanks in advance.
2147483582  2014-Dec-28 15:17:26 Informational   %AAA-I-CONNECT: New http connection for user cisco, source 192.168.0.100 destination 192.168.0.101 ACCEPTED
    2147483583  2014-Dec-28 15:16:44 Warning   %STP-W-PORTSTATUS: gi1: STP status Forwarding
    2147483584  2014-Dec-28 15:16:40 Informational   %LINK-I-Up:  gi1, aggregated (1)
    2147483585  2014-Dec-28 15:16:37 Warning   %LINK-W-Down:  gi1, aggregated (1)
    2147483586  2014-Dec-28 15:16:33 Informational   %LINK-I-Up:  gi1
    2147483587  2014-Dec-28 15:16:30 Warning   %LINK-W-Down:  gi1
    2147483588  2014-Dec-28 15:13:55 Informational   %BOOTP_DHCP_CL-I-DHCPRENEWED: The device has been renewed the configuration on interface Vlan 1 , IP 192.168.0.101, mask 255.255.255.0, DHCP server 192.168.0.1
    2147483589  2014-Dec-28 14:13:55 Informational   %BOOTP_DHCP_CL-I-DHCPRENEWED: The device has been renewed the configuration on interface Vlan 1 , IP 192.168.0.101, mask 255.255.255.0, DHCP server 192.168.0.1
    2147483590  2014-Dec-28 13:41:44 Warning   %STP-W-PORTSTATUS: gi1: STP status Forwarding
    2147483591  2014-Dec-28 13:41:40 Informational   %LINK-I-Up:  gi1, aggregated (1)
    2147483592  2014-Dec-28 13:41:37 Warning   %LINK-W-Down:  gi1, aggregated (1)
    2147483593  2014-Dec-28 13:41:36 Informational   %LINK-I-Up:  gi1
    2147483594  2014-Dec-28 13:41:33 Warning   %LINK-W-Down:  gi1
6 Replies 6
Tom Watts
Hi Eddie, this log message is indicative of the link bouncing (periodically losing connectivity). If your computer has no degraded performance then it looks like a cosmetic informational message. If your computer is actually consistently dropping connectivity then there is a wire issue of some sort.
Possible causes for this error message to scroll can be from;
Link negotiation for speed or duplex
Computer NIC has a software issue
Switch port has a defect
Wire between computer and switch is defective
Software issue on the switch alarming false link flap
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hello there,
It is pretty obvious that the ports are flapping and the issue needs further investigation,
but does anybody know what the numbers in the brackets indicate (in this case 188, 83, 84)?
<188>%LINK-W-Down: gi13, aggregated (84)
<188>%LINK-W-Down: gi13, aggregated (83)
Thanks.
This avoids logging the exact same message over and over, resulting in a log full of the same repeated entry.
If a log entry is repeated N times, it is logged once and "aggregated (N)" is added to the end.
So to answer the question, the number in parentheses is the repetition count.
I think they should use "message repeats N times", but that choice is the privilege of whoever writes the English language version of the software. :P
Hey James, thanks for the reply. It really helped.
I am now trying to figure out what the <188> count indicates.
Thanks.
Salvatore
I just figured out that the <N> count indicates the type of syslog message codes.
Similar incidents present similar <N> counts, that is %STP logs follow a <188> code, %TCP drops follow a <148> code and so forth.
Thanks.
Salvatore
will this behaviour stops if i disable the STP of the switch? Because in my case it's happening for one or two ports...
