Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 1550 Views
  • 1 replies
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant  - Discover support content and options for your gearSupport page index - Contains ...
  • 2985 Views
  • 1 replies
  • 15 Helpful votes
Hi, We have a few similar setups with the same switches stacked.  Setup 1)Two switches, smartport enabled, all yealink phones got the auto voice vlan worked perfectly. Setup 2)Three switches, smartport enabled, all yealink phones got the auto voice v...
jmin by Beginner
  • 404 Views
  • 2 replies
Hi,I have a problem with all the POE outputs of the indicated switch, until before the firmware update, they worked perfectly.. after the update and restart of the switch they worked.About 3 hours after the firmware update ( version 1.4.11.5 ) they s...
Hi,Below I paste a few excerpts from the backed up SG350X's config file:First I have defined a few VLANs and they show up in the config file like this: interface vlan 92name StaffNet92!interface vlan 93name TestNet93!interface vlan 94name ResidentsNe...
BushTor1 by Beginner
  • 310 Views
  • 3 replies
Hello,I got a used Cisco SG200-08P switch missing its power supply. To check if the switch is still in working conditions, I tried to power it up with a PoE injector connected to port 1 without success. I was wondering if this is conclusive evidence ...
mdett by Beginner
  • 642 Views
  • 4 replies
Hello,I'm working on cisco SG300 switch, after collecting traffic data (received octets) from it using snmpget I got this graph: 1.The drop of data from the maximum value may be due to drop in user activities, is there any other reason for this rapid...
