Showing results forĀ
Search instead forĀ
Did you mean:Ā
WARRANTY CHECK
Hamza malik
HI THERE
I WANT TO CHECK WARRANTY OF MY CISCO SWITCH. CBS-350-48P-4G.
SERIAL NUMBER=PSZ264919G5
5 Replies 5
Go to https://cway.cisco.com/mydevices/devices then log in using the correct CCO login.  Enter a valid serial number one by one or by bulk.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
I VISITED THE SITE BUT THERE IS NO LOGIN OPTION .I DID NOT FIND ANY LOGIN PORTAL.
If you are currently logged in (for example using your CCO here) you will not be prompted to login.
There is some option eg, summary, devices, reports and activities. where I have to check warranty?
@Hamza malik hi use this https://cway.cisco.com/sncheck/
I can see its not covered under any contract
Good luck
KB
