05-10-2016 04:18 AM
Hi All,
Please Help Us.
We are using Cisco SG - 300 / 28 port switch
We are configure Vlan and Trunk allow Management vlan commands on switch , but not showing on running config ,and interface .
This are commands using :
EX : Int range gigabitethernet23- 24
switchport mode trunk
switchport trunk allowed vlan add all
no sh
and
Management Vlan :
int vlan 22
name DATA
ip address 10.x.x.x 255.255.255.0 10.X.X.1
Switch Version
SW version 1.3.0.62 ( date 02-May-2013 time 14:55:01 )
Boot version 1.1.0.6 ( date 11-May-2011 time 18:31:00 )
HW version V03
05-12-2016 03:57 AM
Hi Asif,
May be you need to define trunk encapsulation method.
Please check.
If possible, please paste output of show interface <interface name> switchport
Sheshu.
05-12-2016 03:59 AM
Asif,
Looks like I misread your question - Can you tell me if you are not able to configure vlan and allow that vlan in trunk interface.
or you are able to configure all these and they are not showing up in running configuration?
Sheshu.
05-12-2016 04:10 AM
Hi Nagasheshu,
We have configured 20 to 30 cisco sg-300 switch with the same configuration commands !
it is working fine , but issue come with 2 switch only ,
configured on switch but not showing on interface and sh run configuration !
no sh
and
Management Vlan :
int vlan 22
name DATA
05-12-2016 04:42 AM
if possible, can you please paste the configuration from victim switch?
show interfaces configuration
show interfaces switchport <interface>
show interfaces status
show running-config.
