Web Interface for SF300-24 Managed Switch
So I am having trouble accessing the web interface for my switch. I am in the command line and it shows as follows when I put in the command show ip interface:
Gateway IP Address Activity status Type
192.168.1.1 Active static
IP Address I/F Type Status
192.168.1.253/24 vlan 1 Static Valid
switcha4b98f#
however when I try typing the ip address into the web browser it times out. I know that the Ip http server could be disabled by default. I just need to know the command line commands to enable it.
8 Replies 8
balaji.bandi
by default, the ip address is 192.168.1.254 for a new one (Hope you have not changed this ? if not changed)
Follow the below steps :
STEP 4 Enter the switch IP address in the address bar and press Enter. For
example, http://192.168.1.254.
The Switch Login Page displays.
STEP 5 Enter the default login information:
• Username is cisco
• Default password is cisco (passwords are case sensitive)
BB
I did change it to 192.168.1.253 do I need to factory rest and try again?My
default gateway is on the same subnet as the default ip address for the
switch but I haven't been able to web interface.
After changing the IP address have you rebooted the device? if not please reboot the device.
From PC you able to ping IP address? 192.168.1.253
then try from your browser https://192.168.1.253 and let us know outcome ?
BB
I do a factory reset on the switch and when I get into the command line I get this
0.0.0.0/32 vlan 1 DHCP Not
received
192.168.1.254/24 vlan 1 Valid
switcha4b98f#
I tried typing https://192.168.1.254 into the web browser it times out.I tried to ping from my computer and I get destination host unreachable.
What is your PC IP address here while pinging to your 192.168.1.254 ?
2 Options  here :
1. you need to connect your PC to one of the port  Switrch, So Switch can offer you DHCP IP.
or
2. You can configure your PC with Static IP (Example)
IP : 192.168.1.253
mask : 255.255.255.0
gateway 192.168.1.254
ping 192.168.1.254 from PC, if success
try https://192.168.1.254 or http://192/168.1.254
BB
My computer's IP is 192.168.1.10 and Im going by the default IP address is 192.168.1.254,but when I type that into the web browser it times out and Im unable to ping to it from my computer
You need to able to ping  192.,168.1.254, m ake sure you connected port on the switch no shutdown mode.
So sort this before you go to Web access.
BB
When I input the no shutdown command I get command unrecognized I will show the commands I enter as follows:
switcha4b98f(config-if)#ip address 192.168.1.254 255.255.255.0
Please ensure that the port through which the device is managed has the proper
settings and is a member of the new management interface.
Would you like to apply this new configuration? (Y/N)[N] Y
switcha4b98f(config-if)#no shutdown
% Unrecognized command
