04-10-2012 10:31 AM
I have my network with serie 300 switches. One is working in layer 3 mode and all others switches are in layer 2 mode.
I dont have redundant path between switches. Should I enable STP? or is not necessary?
Thanks a lot.
Solved! Go to Solution.
04-10-2012 12:48 PM
Hi Ruy,
It is rare for STP to cause problems. There are a few rare cases that it will cause a problem but overall having STP enabled should not impact your network.
I would recommend double checking everything on your network before disabling STP. It only takes one missed cable and your whole network will freeze in a broadcast storm.
04-10-2012 11:03 AM
If you don't have redundant paths, STP is not necessary but can be useful to prevent problem do to accidental loop.
Regards.
04-10-2012 11:11 AM
Daniele, Thanks for you reply.
If I dont have redundant path but I anyway enable STP could be some problem or its ok?
thanks!
04-10-2012 12:48 PM
Hi Ruy,
