Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2800 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4338 Views
  • 1 replies
  • 16 Helpful votes
Here is my network layout:I have a cable modem connecting to a Linksys WRT54GL (DDWRT) router. Port 1 on the WRT54GL is connect to port 01 on the SG300-10 switch. On the SG300-10 I've created two Vlans (Vlan 30 & Vlan 40). I assigned ports 3 & 4 on t...
Hello everyone,I have a SG200-26 model but I'm having issues updating the firmware image through GUI and TFTP.  I just recently bought this and used it as a regular switch.  Until I wanted to manage certain ports, I found out the GUI was Linksys bran...
jtuyen888 by Level 1
  • 2760 Views
  • 0 replies
I configured a new SG-200-08 with a static IP. I tried to save the configuration as the startup configuration. After 10 minutes, I restarted the switch. It didn't boot with the new configuration, and returned to the default .254 and default pw. Now I...
Hi my name is Rey Capoy.  I am new to networking and got a task of configuring an SGE2010P.  Our client wants us to configure mulitple VLANs on their network. I have attached a raw diagram on their network. The bottom part of the diagram shows netgea...
reycapoy by Level 1
  • 1098 Views
  • 2 replies
Hi all,I have a Cisco SG300 switch on which trunks are configured. I have a server which sits on the switch via a trunk link of four network cables (4 Gbps total)on which LACP is enabled. I'm having trouble connecting to the server using VNC from a c...
Hi,I have a SG300-10 in layer 3 mode attached to a Fortinet firewall (FG). The Fortinet syslog is reporting repeated traffic violations with the following info:src: << IP of the interface that the SG is attached to >>dst: << IP of system connected to...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
