10 G connectivity between X2 & SFP
sagar.sarker
I want to connect WS-C2960S-48TD-L switch to WS-X6708-10G-3CXL module in Cisco WS-C6503-E switch. WS-X6708-10G-3CXL is C6K 8 port 10 Gigabit Ethernet module with DFC3CXL which requires X2 module. on the otherhand, WS-C2960S-48TD-L requires SFP+. Now is it possible to interconnect these two switch interfaces if I use LIU in between. or does WS-X6708-10G-3CXL module supports CVR-X2-SFP+ to use SFP+ transceivers.
Sagar
Reza Sharifi
Sure, you can connect them together.
The 6500 side is SC type connector and the 2960 side is LC type connector. So, all you need is a fiber patch cord with one side LC (2960) and one side SC (6500).
Reza Sharifi
Reza Sharifi
BTW, if your optics are Single Mode (SM) you need SM patch cord.  If they are you Multi-mode (MM) you need MM fiber.  The fiber patch cord has to match the optics.
