100BASE-FX DUPLEX MISMATCH
javiercastro
Level 3
Level 3
I have the following issue with two switches connected through a 100Base-FX link. On one side there is a WS-C2950C-24 (fixed configuration switch with two native 100Base-FX ports) and on the other side there is a WS-C2960-24TC-L using a 100Base-FX SFP module. The problem is that on the 2950 the port is operating at 100Mpbs/Full-Duplex but at the 2960 the port is operating at 100Mbps/Half-Duplex. I am not being able to set duplex mode to full from interface configuration because the command is neither available nor hidden, the IOS version is 12.2(25)SEE2.
As you can see from the show interface command, the 2950 side is working as expected but on the 2960 side is working half-duplex:
SW_2950#sh inter faste0/25
FastEthernet0/25 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0017.0efe.6dd9 (bia 0017.0efe.6dd9)
Description: Enlace a Pintado
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseFX
input flow-control is unsupported output flow-control is unsupported
Last input 00:00:00, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 106000 bits/sec, 54 packets/sec
5 minute output rate 106000 bits/sec, 55 packets/sec
851275 packets input, 170936567 bytes, 0 no buffer
Received 93676 broadcasts (0 multicast)
713 input errors, 713 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 90199 multicast, 0 pause input
890989 packets output, 205010324 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Sw_2960#sh inter gi0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0019.e718.a519 (bia 0019.e718.a519)
Description: Enlace a MDF Galvanizado
Keepalive not set
Half-duplex, 100Mb/s, link type is auto, media type is 100BaseFX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output 00:00:00, output hang never
5 minute input rate 92000 bits/sec, 54 packets/sec
5 minute output rate 90000 bits/sec, 52 packets/sec
902545 packets input, 207570936 bytes, 0 no buffer
Received 121948 broadcasts (0 multicast)
0 watchdog, 86423 multicast, 0 pause input
863562 packets output, 173504349 bytes, 0 underruns
0 output errors, 298 collisions, 1 interface resets
0 babbles, 740 late collision, 0 deferred
Is there any way to force the 2960 to operate full duplex?
I also noticed that the interface is referenced as "gigabitethernet" from CLI eventhough the 100Base-FX is recognized at the show interface level.
glen.grant
It won't take the "duplex full" command ? that is strange . Is the SFP module one from Cisco , non cisco sfp can cause problems . I would pull the sfp module , default the interface and then reinsert the sfp module see if it recognizes it better . If not could be a faulty sfp .
For SFP module ports, the speed and duplex CLI options change depending on the SFP module type.
The 100BASE-x SFP module ports support only 100 Mbps. These modules support full- and half- duplex options but do not support autonegotiation
Try to Reconfigure the Media Type to SPF and set the Duplex
Danny
