100Mb SFP in 1000Mb Port
Highnet_TSC
I am struggling to find an SFP transceiver, single mode, that operates at 100Mbps in a 1000Mbps port in an ME3600 or ME3800.
Is there such a transceiver?
5 Replies 5
Giuseppe Larosa
Hello Duncan,
see the 100 Mbps SFP compatibility matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html
the SFP exists for SMF
GLC-FE-100EX=
100BASE-FX SFP module for 100-MB ports, 1310 nm wavelength, 40 km over SMF
GLC-FE-100LX=
100BASE-FX SFP module for 100-MB ports, 1310 nm wavelength, 10 km over SMF2
on table 4 are reported the supported models for metro ethernet switches and minimum IOS version
ME-3600X-24FS-M
(client ports only)
Hope to help
Giuseppe
Hi Giuseppe
Those are for use in 100Mb ports, aren't they?  I'm looking, essentially, for an SM equivalent of GLC-GE-100FX=
Hello Duncan,
you are right I have misread their descriptions
I'm afraid a SMF module is not available if so, you should use an external converter from MMF to SMF
Best Regards
Giuseppe
Hi Giuseppe
The GLC-GE-100FX does not appear to be compatible with the ME3800-24FS-M (which are the models I use).
I'm pretty confused, though.  It says that GLC-FE-100LX are compatible, but also that they only work in 100Mb SFP ports.  The ME3800-24FS-M doesn't have any 100Mb SFP ports, they're all 1000Mb, so how could it be compatible...
Hello Duncan,
C3800X data sheet clearly states that these 100 Mbps SFP are supported
see
SFP ports:
• 10/100/1000BASE-T SFP-based ports: RJ-45 connectors, 4-pair Category 5 UTP cabling
• >>>100BASE-FX and -LX: Duplex LC receptacle fiber connectors (multimode and single-mode)
http://www.cisco.com/en/US/prod/collateral/switches/ps10905/ps10965/data_sheet_c78-601950.html
So they may be the solution for your connectivity needs.
The switch port may be so smart to perform speed change when detecting  the 100BASE FX SFP.
Hope to help
Giuseppe
