887W two ssid routing between VLAN
mgregory
Hi, I created a second VLAN and a second SSID. My problem is that from a PC on the native VLAN 1 I can ping the IP of VLAN 2 192.168.2.254 but I cannot ping any other device that has connected to the second SSID.
How do I get routing to work between the two VLAN? I thought it would be automatically setup when I created the second VLAN using Cisco Configuration Professional?
regards, Mark
Sandeep Choudhary
can you  just paste your topology(rough diagramm) to better understand the problem??
If you have switch between then , did you configure 2nd  vlan on switch ???
Hi, I'm not sure how to do that.
I have a LAN subnet 192.168.1.0 with gateway 192.168.1.254 and this is the native VLAN 1 SSID MyAP on my wireless.
I created a second VLAN 2 with IP 192.168.2.254 and a second SSID MyAP2.
I can connect to MyAP2 and to MyAP
I can ping devices on MyAP from the local LAN
I cannot ping devices on MyAP from the local LAN
I can ping 192.168.2.254
I have PCs on 192.168.1.xxx
regards,
Mark
do you have switch between your pc and wireless router ?????
if yes then
can you post the outpout of this command from switch :
sh vlan
