10Gb link between 2 3750X switches with C3KX-NM-10G modules
joopv
Home lab situation:
I have 2 3750X-48PF-L switches with C3KX-NM-10G modules and i'm trying to create a 10Gb link, using a third-party twinax cable with sfp+ connections.  To be exact: a D-link DEM-CB100S direct attach SFP+ to SFP+  50cm copper cable.
There is no 10G link coming up.  There IS a gigabit link coming up when i plug the cable in the 1G slots of the NM-10G module, but no 10G when i plug the cable in the TE1 / TE2 slots.  Message " %PHY-4-SFP_PLUS_NOT_SUPPORTED: The SFP PLUS in Te1/1/2 is not supported"
"service unsupported-transceiver" and "no errdisable detect cause gbic-invalid" are already activated, and the switches are running 15.2.4.E10.  Switches have 256M ram / 64M flash and a lanbase license.
Should this work or ... ?
as per the log message, the transceiver you are trying to use is not supported to 10G module. you need to go with cisco 10G transceiver to create link between switches.
rate this and mark as answer if this solved your concern
Good luck
KB
pman
To see what type and from what vendor the existing SFP is
  • show controllers ethernet-controller tengigabitethernet1/1/2 phy
  • show interfaces tengigabitethernet1/1/2 status
  • show interface x/y
  Auto-duplex, Auto-speed, link type is auto, media type is  1000BaseCX SFP Cable --> Check this
to display the list of DOM-supported transceivers on the switch
  • show interfaces transceiver supported-list
joopv
Thanks for your reply,
Switch#show controllers ethernet-controller te1/1/1 phy
TenGigabitEthernet1/1/1 (gpn: 29, port-number: 1)
SFP+ Transceiver Module Serial EEPROM Contents:
Common block:
Identifier : SFP
Connector : [0x21]
Transceiver
Type : SFP-10GBase-CX1 SFP-10GBase-ER
Speed : 100/200/400 MBytes/Sec (tri speed support) [0xD5]
Media : [0x80]
Technology : [0x04]
Link Length : [0x00]
Encoding : [0x00]
BR, Nominal : 120x100 MHz [0x78]
Rate Identifier : [0x00]
Length(9u) :
Length(50u) : [0x00]
Length(62.5u) : [0x00]
Length(OM3) : [0x00]
Vendor Name : JESS-LINK
Vendor OUI : 0x0 0x18 0x97
Vendor PN : P3400XA01000-2
Vendor rev : A0
CC_BASE : 0x8C
Extended ID Fields
Options :
Class : Limiting Class [0x00]
More Options : [0x00]
BR, max : Unspecified
BR, min : Unspecified
Vendor SN : <deleted>
Date code : 120904
DOM Type : [0x00]
CC_EXT : 0xC1
Vendor Specific ID Fields:
0x00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Device : SFP_PLUS PMA PMD
0000: 2040 : 0010 0000 0100 0000
0001: 0082 : 0000 0000 1000 0010
0002: 0020 : 0000 0000 0010 0000
0003: 6036 : 0110 0000 0011 0110
0004: 0001 : 0000 0000 0000 0001
0005: 009B : 0000 0000 1001 1011
0006: 0000 : 0000 0000 0000 0000
0007: 0008 : 0000 0000 0000 1000
0008: BF01 : 1011 1111 0000 0001
0009: 0000 : 0000 0000 0000 0000
Device : SFP PLUS PCS
0007: 0000 : 0000 0000 0000 0000
0008: 8C01 : 1000 1100 0000 0001
Device : SFP_PLUS XGXS
0002: 0143 : 0000 0001 0100 0011
0003: BFF0 : 1011 1111 1111 0000
0005: 0093 : 0000 0000 1001 0011
0008: 8C00 : 1000 1100 0000 0000
00-10-18, 03-06, 01-04
Switch#
Switch#sh int te1/1/1
TenGigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is <deleted>
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Switch#sh int transceiver supported-list
Transceiver Type Cisco p/n min version
supporting DOM
GBIC DWDM ALL
GBIC RX only WDM ALL
GBIC CWDM NONE
GBIC SX NONE
GBIC LX NONE
GBIC ZX NONE
XENPAK DWDM ALL
XENPAK ZR ALL
XENPAK Rx only WDM ALL
XENPAK ER SOME
XENPAK LR SOME
XENPAK LW ALL
XENPAK SR NONE
XENPAK LX4 NONE
XENPAK CX4 NONE
X2 DWDM ALL
X2 CWDM ALL
X2 ZR ALL
X2 ER ALL
X2 LR ALL
X2 LW ALL
X2 LRM ALL
X2 SR ALL
X2 LX4 NONE
X2 CX4 NONE
XFP DWDM ALL
XFP CWDM ALL
XFP ZR ALL
XFP ER ALL
XFP LR ALL
XFP LW NONE
XFP SR ALL
XFP LX4 NONE
XFP CX4 NONE
SX_SFP_100 NONE
LX_SFP_100 NONE
ZX_SFP_100 NONE
DWDM SFP ALL
CWDM_SFP ALL
Rx_only_WDM_SFP NONE
SX_SFP SOME
LX_SFP SOME
ZX_SFP SOME
GigE BX U SFP ALL
GigE BX D SFP ALL
GLC 2BX U SFP ALL
GLC 2BX D SFP ALL
EX SFP ALL
10GE SR SFP+ ALL
10GE LR SFP+ ALL
10GE ER SFP+ ALL
10GE LRM SFP+ ALL
10GE USR SFP+ ALL
10GE LRM SM SFP+ ALL
10GE ZR SFP+ ALL
100BaseTX T1/E1 SFP SOME
10GE DWDM SFP+ ALL
10GE BX U SFP+ ALL
10GE BX D SFP+ ALL
10GE BX40 U SFP+ ALL
10GE BX40 D SFP+ ALL
GLC BX40D SFP ALL
GLC BX40DA SFP ALL
GLC BX80D SFP ALL
GLC BX40U SFP ALL
GLC BX80U SFP ALL
Switch#
Switch#
