12-24 port small form factor ethernet/Fiber sfp based switch?
Patrick Beaven
Does anyone know of a cisco switch with 12-24 sfp ports (ethernet fiber attached) for aggregating fiber for a small campus setup.
I have seen the 3400CS with 12 fiber ports but need somthing slightly larger.
Any ideas?
Nagaraja Thanthry
You could consider 3750G-12S:
Cisco Catalyst 3750G-12S -- 12 SFP ports
This will have 12 SFP ports. If you like, you could buy two of them and
stack them to configure as a single switch.
Hope this helps.
NT
Assuming you want 1G for the SFP. You can also try the Catalyst 4928 (no stacking needed)
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9903/data_sheet_c78_494757.html
HTH,
jerry
Have you seen this switch:
http://www.cisco.com/en/US/prod/collateral/switches/ps6568/ps10956/data_sheet_c78-601946.html
* Cisco ME 3600X Series Ethernet Access Switches
Jeremy
Leo Laohoo
3560E-12D with TwinGig converters.
