169 IP issue in specific Vlan
Shadow_200
Hi All ,
I am getting 169.X.X.X IP in vlan 103.
As i checked DHCP pool for same vlan, Pool was not full. aslo there are no IP conflict .
as I change the interface vlan from 103 to 104 , system take the IP from vlan 104 and when I revert it back to vlan 103 then system easily take IP from Vlan 103. and after some time system realeased the IP and again take 169 IP.
Multiple users in single vlan is affected .
Please suggest.
7 Replies 7
 This is a real device or simulador?
 Something you can do to work around is extend the lease time but for sure something weird is there.
 It is a good idea look in the logs or/and debug.
this is real working scenario .
show ip dhcp statistic <<- share this please
also are you use any dhcp exclude with broadcast subnet mask ?
this is C9300-24Y device and dont know why but sh ip dhcp statistics  command is not taking by device .
getting option like.
sh ip dhcp ?
binding
conflict
database
exclude-address
import
limit
pool
relay server
snooping
vrf
and I am not using ip dhcp exclude with braodcast subnet mask.
IOS version 17.05.01
Some times it take and other it not!!
Now let start TS
The vlan103 have SVI and vlan104 have SVI both have pool with correct GW point to SVI IP of vlan103/104
Can I see this config ?
Are you using any l2 secuirty in SW like dhcp snooping DAI ..etc. ?
Shadow_200
interface Vlan103
ip address 10.41.44.2 255.255.255.0
standby 103 ip 10.41.44.1
standby 103 priority 90
standby 103 preempt
arp timeout 240
interface Vlan104
ip address 10.41.45.2 255.255.255.0
standby 104 ip 10.41.45.1
standby 104 priority 150
standby 104 preempt
arp timeout 240
snooping configuration on L2
sh run | i snooping
ip dhcp snooping vlan 1-2,50,55,100-105
no ip dhcp snooping information option
ip dhcp snooping
ip dhcp snooping trust
https://www.routexp.com/2019/08/configure-hsrp-aware-dhcp-relay.html
the HSRP explain some of this unnormal behave,
the HSRP must config with dhcp reply and the DHCP server must point to other Network Device and not run DHCP in any of HSRP peer
