1811w went into romon
mahesh parmar
Beginner
Beginner
Hi all,
After restarting the 1811w went into romon.
i try the xmodem command it shows
rommon 2 > xmodem -c c181x-adventerprisek9-mz.151-4.M6
Do not start the sending program yet...
dir: cannot open device "flash:"
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
ERR: Not enough memory to download image
is there any command  that can erase ios from flash when in romon mode?
mahesh
Leo Laohoo
VIP Community Legend VIP Community Legend
The IOS you intended to use cannot boot because the IOS requires more DRAM/Flash than what your router has.
Command:  del flash:filename.extension
Leo Laohoo
Hi Leo,
Thanks for help.
Seems Compact flash card in front of router pop up for some reason it put the card back and router booted the ios.
Before this i try so many different things but it was not booting from flash as router was not seeing the flash.
Sometimes small things cause big issues
Mahesh
LOL.
Thanks Mahesh.
Recognize Your Peers
