4948 Running Configuration
Hello !
If anyone over here can post a running configuration sample of Cisco 4948 Switch.
I need to know the interface numbering, specifically of the SFP ports.
Zeeshan Sanaullah
2 Accepted Solutions
allan.thomas
Level 8
Level 8
Hi Zeeshan,
Hopefully this is the information that you are looking for.  Essentially there are 52 physical interfaces on the 4948, however the last 8 interfaces are still numbered the same gigabit 1/45 - 1/48 and are simply configured as either RJ45 or SFP.  Please take a look at the following guide, you will see that you simply have to specify the media-type under the interface:-
"The interface configuration mode command media-type sfp|rj45 can be used to configure the media  type for these ports in the switch software and determines whether the  SFP or the RJ-45 connector is used. The default is SFP."  Taken from this link:-
http://www.cisco.com/en/US/docs/switches/lan/catalyst4900/4948/05modcfg.html
Allan.
Hope this helps, pls rate helpful posts.
Hi Zeeshan,
The interface number is as follows, these are simply configured as host ports with speed and duplex fixed or left to auto.  Whereas Gigabit1/45-1/48 would typically be your SFP Trunk uplinks to your distribution or core layer using single interface or bundled as port-channel:-
vlan 2
name Vlan2
vlan 3
name Vlan3
vlan 4
name Vlan4
vlan 5
name Vlan5
vlan 6
  name Vlan6
vlan 7
  name Vlan7
vlan 8
  name Vlan8
vlan 9
  name Vlan9
vlan 10
  name Vlan10
interface GigabitEthernet1/1
switchport access vlan
speed 1000
duplex full
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/44
speed 1000
duplex full
spanning-tree bpduguard enable>
interface GigabitEthernet1/45
  description Link to Core Switch A
  switchport trunk native vlan 1
  switchport trunk allowed vlan 2-10
  switchport mode trunk
  channel-group 1 mode desirable non-silent
interface GigabitEthernet1/46
interface GigabitEthernet1/47
  description Link to Core Switch B
channel-group 2 mode desirable non-silent
interface GigabitEthernet1/48
interface Vlan10
ip default-gateway 192.168.1.254
Allan.
5 Replies 5
allan.thomas
Level 8
Level 8
Hi Zeeshan,
Allan.
Allan,
Thanks. I got what I was looking for. One more thing about interface numbering.
Is it Interface Gigabitethernet 0/1 or Gigabitethernet 1/1 for ports on 4948.
Actually I need to develop Configuration templates for this switch but does not physically have the switch right now. If you have this switch then please post a sample running configuration
Zeeshan Sanaullah
Hi Zeeshan,
vlan 2
name Vlan2
vlan 3
name Vlan3
vlan 4
name Vlan4
vlan 5
name Vlan5
vlan 6
  name Vlan6
vlan 7
  name Vlan7
vlan 8
  name Vlan8
vlan 9
  name Vlan9
vlan 10
  name Vlan10
speed 1000
duplex full
speed 1000
duplex full
interface Vlan10
Allan.
It worked for me, too. Thanks.
Are the SFP's numbered this way on the 4948e?  I could not locate a picture with a high enough resolution, to see the numbering on the ports.
