1841 bandwidth limitation (traffic shapping) not working
gasparmenendez
Level 3
Level 3
Hi folks,
I have a problem with bandwidth limitation on a Cisco 1841 Router. The thing is that I need to limit the internet bandwidth with class and policy maps in my 1841 but it's not working... when I check my Cacti (monitoring system) it shows 1841 is using more than 2 Mbps, when apparently I limited to 1 Mbps. Here's is my configuration:
Building configuration...
Current configuration : 2548 bytes
version 12.4
service password-encryption
hostname IntRegManzanas
boot-start-marker
boot-end-marker
enable secret 5 $1$r/qO$L.tQ0JnkA
enable password 7 1511021
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone MX -6
clock summer-time MX recurring
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool REDINTERNA
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 189.194.28.161 200.52.167.161
ip domain name somosggl.com
username gaspar privilege 15 password 7 094B4F1A0
username extra privilege 15 password 7 10692E3500
archive
 log config
  hidekeys
ip ssh version 2
class-map match-all CLASS1M
 match access-group name ACL1M
policy-map POLICE1M
 class CLASS1M
   police cir 1000000 bc 187500 pir 1000000
interface FastEthernet0/0
 description *** Externa ***
 ip address 10.227.225.33 255.255.252.0
 ip nat outside
 ip virtual-reassembly
 rate-limit input 1000000 187500 375000 conform-action transmit exceed-action drop
 rate-limit output 1000000 187500 375000 conform-action transmit exceed-action drop
 duplex auto
 speed auto
interface FastEthernet0/1
 description *** Interna ***
 ip nat inside
 duplex auto
 speed auto
 service-policy output POLICE1M
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.227.224.1
ip http server
no ip http secure-server
ip nat inside source list 110 interface FastEthernet0/0 overload
ip access-list standard ELCACTI
 permit 10.227.224.11
 deny   any
ip access-list extended ACL1M
 deny   ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip 192.168.1.0 0.0.0.255 any
logging 10.227.224.11
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
snmp-server community ******** RO ELCACTI
snmp-server location Canatlan
snmp-server contact Irma Mtz
control-plane
banner login ^C
    Acceso restringido
   Solo personal autorizado
^C
line con 0
 password 7 040F5D515
 logging synchronous
line aux 0
line vty 0 4
 logging synchronous
 transport input all
scheduler allocate 20000 1000
end
Can somebody help me please??
Thanks in advence. BR.
40 Replies 40
Hello
Policing is applicable for egress traffic but its more relevant for ingress traffic, So all you need is to police ingress as close to you source traffic as possible
As shown by Georg and myself you can match via a access-list or interface for you traffic
access-list 100 permit ip any any
class-map match-any Police_cm
match ip address 100
or
match input-interface x/x
Policy-Map Police _lan_pm
class Police_cm
police 1024000 conform-action transmit  exceed-action drop
Int x/x
description Lan_facing_interface
service-policy input Police _lan_pm
Note: dropping you exceed traffic can be very disruptive, usually you would reclassify the excesses so it at least gets through be it at a more lower classification.
Looking at you testing, you still have the load-interval set a 5 minute, can you drop it to show a more realistic utilization value and change you class-map to a mach-any
Test the example above and share you results.
res
Paul
Kind Regards
Paul
hello Paul, just one detail ( I think I asked you about this before), Router don't accept match ip address 100 so I changed by match access-group 100, is that ok???
anyway I configured like you suggested and now I have this:
IntRegManzanas#show policy-map interface FastEthernet0/1
 FastEthernet0/1
  Service-policy input: Police_lan_pm
    Class-map: Police_cm (match-any)
      10398 packets, 1025352 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: access-group 100
        10115 packets, 996651 bytes
        30 second rate 0 bps
      police:
          cir 1024000 bps, bc 32000 bytes
        conformed 10398 packets, 1025352 bytes; actions:
          transmit
        exceeded 0 packets, 0 bytes; actions:
          drop
        conformed 0 bps, exceed 0 bps
    Class-map: class-default (match-any)
      104 packets, 11044 bytes
      Match: any
now I'm going to wait and see what happens.
Thanks.
just one question: in your original post you say that you are using Cacti to monitor traffic. What are you monitoring, individual IP flows from end users ? And if, how have you set this up ?
I am just asking because I only know Cacti as a network traffic monitoring solution,and not necessarily one that can measure individual end user traffic...
that's correct Georg, I'm using Cacti to monitor individual end users, by IP address. Here's the graffic for the client:
 this is from right now:
 FastEthernet0/1
      166605 packets, 23895063 bytes
      30 second offered rate 4000 bps, drop rate 0 bps
        166322 packets, 23866362 bytes
        30 second rate 4000 bps
      police:
        conformed 166452 packets, 23696060 bytes; actions:
          transmit
        exceeded 153 packets, 199003 bytes; actions:
          drop
        conformed 4000 bps, exceed 0 bps
      Match: any
which IP address belongs to that graphic ?
sorry for the confusion. What I meant to say: the graph represents an IP address in the 192.168.1.0/24 range, right ? Which one ?
oh I'm sorry Georg, I missunderstood your question...
graffic represents ALL traffic in the interface, not just one IP address. That would be traffic for all 192.168.1.0/24. But in this case specific that's traffic for the OUTSIDE interface (the one NOT facing the LAN).
Anyway bandwidth is still uncontrolled, yesterday it reached 3 Mbps....
Hard to believe, isn't it??
Thanks.
Hello
something is a miss here -Can you please confirm
1)are you applying  the policy- map to lan facing interface of your wan rtr ?
2) is your Acl matching traffic coming off that lan interface ?
3)  are you checking the corrct service policy  it again should.be applied to the lan interface
Res
paul
Kind Regards
Paul
hi Paul, allow me to send you the running config (the one running right now). Only most relevant parts:
IntRegManzanas#sh running-config
Current configuration : 2335 bytes
version 12.4
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
ip cef
  hidekeys
ip ssh version 2
policy-map Police_lan_pm
 class Police_cm
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 load-interval 30
 duplex auto
 speed auto
 service-policy input Police_lan_pm
ip http server
 deny   any
and this is right now:
 FastEthernet0/1
      1074079 packets, 151048164 bytes
      30 second offered rate 1000 bps, drop rate 0 bps
        1073796 packets, 151019463 bytes
        30 second rate 1000 bps
      police:
        conformed 1071493 packets, 148576338 bytes; actions:
          transmit
        exceeded 2586 packets, 2471826 bytes; actions:
          drop
        conformed 1000 bps, exceed 0 bps
      Match: any
Thanks.
Here is what I think needs clarification:
1. Your configuration limits individual users on the 192.168.1.0/24 subnet to 1MB.
2. Cacti measures the throughput of the ENTIRE interface, which is the SUM of all individual users.
In order to see if the policing works for individual users, use the site below on the clients. Upload and download should be limited to 1MB.
http://beta.speedtest.net/
hi Georg,
my configuration limits the traffic to 1Mbps in the interface, to the whole network (192.168.1.0/24) regardless the client's office use 1, 2, 3 or 254 PC's (or at least is what I need to do). That's why I use Cacti to monitor the traffic for the LAN interface. I need that total bandwidth in the LAN interface don't be more than 1Mbps. Sorry if I don't made myself clear.
Thanks.
Hello
          transmit
          drop
        conformed 1000 bps
I guess it isn't 3 mb at present!
Can you do this please, and then test once more
1) class-map match-any Police_cm
match input-interface FastEthernet0/1
2) from inside you network ( that's from a host originating from within fa0/1) can you create an extended ping to a outside destination with with 1500 bytes
ping x.x.x.x -l 1500 -n 100000000 ( this is a windows command)
3) clear counter interface fa0/1
then post results
res
Paul
Kind Regards
Paul
hi Paul, after did what you suggested me:
I've got this:
 FastEthernet0/1
      519163 packets, 47598897 bytes
      30 second offered rate 34000 bps, drop rate 0 bps
      Match: input-interface FastEthernet0/1
        519162 packets, 47598897 bytes
        30 second rate 34000 bps
      police:
        conformed 497454 packets, 45210276 bytes; actions:
          transmit
        exceeded 21709 packets, 2388621 bytes; actions:
          drop
        conformed 34000 bps, exceed 0 bps
      0 packets, 0 bytes
      Match: any
sorry but I don't have access to inside network since that's client's side...
Traffic still going above 1Mbps.
Thanks.
Hello
where you do see the traffic hitting over 1mb
30 second rate 34000 bps <-------------- and this isn't exceeding 1mb
Res
paul
Kind Regards
Paul
