1841 bandwidth limitation (traffic shapping) not working
gasparmenendez
Level 3
Level 3
Hi folks,
I have a problem with bandwidth limitation on a Cisco 1841 Router. The thing is that I need to limit the internet bandwidth with class and policy maps in my 1841 but it's not working... when I check my Cacti (monitoring system) it shows 1841 is using more than 2 Mbps, when apparently I limited to 1 Mbps. Here's is my configuration:
Building configuration...
Current configuration : 2548 bytes
version 12.4
service password-encryption
hostname IntRegManzanas
boot-start-marker
boot-end-marker
enable secret 5 $1$r/qO$L.tQ0JnkA
enable password 7 1511021
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone MX -6
clock summer-time MX recurring
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool REDINTERNA
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 189.194.28.161 200.52.167.161
ip domain name somosggl.com
username gaspar privilege 15 password 7 094B4F1A0
username extra privilege 15 password 7 10692E3500
archive
 log config
  hidekeys
ip ssh version 2
class-map match-all CLASS1M
 match access-group name ACL1M
policy-map POLICE1M
 class CLASS1M
   police cir 1000000 bc 187500 pir 1000000
interface FastEthernet0/0
 description *** Externa ***
 ip address 10.227.225.33 255.255.252.0
 ip nat outside
 ip virtual-reassembly
 rate-limit input 1000000 187500 375000 conform-action transmit exceed-action drop
 rate-limit output 1000000 187500 375000 conform-action transmit exceed-action drop
 duplex auto
 speed auto
interface FastEthernet0/1
 description *** Interna ***
 ip nat inside
 duplex auto
 speed auto
 service-policy output POLICE1M
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.227.224.1
ip http server
no ip http secure-server
ip nat inside source list 110 interface FastEthernet0/0 overload
ip access-list standard ELCACTI
 permit 10.227.224.11
 deny   any
ip access-list extended ACL1M
 deny   ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip 192.168.1.0 0.0.0.255 any
logging 10.227.224.11
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
snmp-server community ******** RO ELCACTI
snmp-server location Canatlan
snmp-server contact Irma Mtz
control-plane
banner login ^C
    Acceso restringido
   Solo personal autorizado
^C
line con 0
 password 7 040F5D515
 logging synchronous
line aux 0
line vty 0 4
 logging synchronous
 transport input all
scheduler allocate 20000 1000
end
Can somebody help me please??
Thanks in advence. BR.
40 Replies 40
bc is in bytes, so a bc of 187500 equals 1.5MB.
Try the below values:
police cir 1000000 bc 8000 pir 8000
rate-limit input 1000000 8000 8000 conform-action transmit exceed-action drop
ok let me try that and get I'll get back to you.
anyway what's the exact way to calculate this??
Thanks. BR.
attach the service policy to the outside interface. I have also made a few change to your policy and access lists (in bold):
version 12.4
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
ip cef
archive
log config
hidekeys
ip ssh version 2
policy-map POLICE1M
class CLASS1M
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip http server
deny any
control-plane
banner login ^C
Acceso restringido
^C
line con 0
logging synchronous
line aux 0
line vty 0 4
logging synchronous
transport input all
end
Hi, I forgot to tell you about this:
IntRegManzanas(config-pmap-c)#police cir 1000000 bc 8000 pir 8000
Inconsistent PIR value, should be greater than CIR: 1000000
that's why I did set pir=1000000
and this is my access-list:
should I change it by yours???
Thanks.
if you configure just the below, what is the output of 'show policy-map interface FastEthernet0/1?
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
class-map match-any CLASS1M
 match access-group 101
policy-map POLICE1M
 class CLASS1M
  police cir 1000000
after been configured like you suggested here's the output:
IntRegManzanas#show policy-map interface FastEthernet0/1
 FastEthernet0/1
  Service-policy output: POLICE1M
    Class-map: CLASS1M (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group 110
        0 packets, 0 bytes
        5 minute rate 0 bps
      police:
          cir 1000000 bps, bc 31250 bytes
        conformed 0 packets, 0 bytes; actions:
          transmit
        exceeded 0 packets, 0 bytes; actions:
          drop
        conformed 0 bps, exceed 0 bps
    Class-map: class-default (match-any)
      4717 packets, 6121306 bytes
      5 minute offered rate 137000 bps, drop rate 0 bps
      Match: any
Thanks.
there is nothing matching the class map.
Try and add the following to the access list matching the class map:
permit ip 192.168.1.0 0.0.0.255 host 192.168.1.1
this is what I configured:
policy-map POLICE1M
 class CLASS1M
   police cir 1000000
and now I'm getting this:
 FastEthernet0/1
      24 packets, 1680 bytes
      Match: access-group name ACL1M
        0 packets, 0 bytes
        5 minute rate 0 bps
      police:
        conformed 24 packets, 1680 bytes; actions:
          transmit
          drop
      204640 packets, 266057008 bytes
      5 minute offered rate 948000 bps, drop rate 0 bps
      Match: any
let's see if now it works.
Thanks.
Actually, you can configure the access list as below. You don't need to deny traffic from 192.168.1.0/24 to 192.168.1.0/24, since that traffic is not even routed and would never hit the interface:
anyway I can't get limit traffic, it reach 2.49 Mbps today. Check this:
 FastEthernet0/1
        0 packets, 0 bytes
        5 minute rate 0 bps
      police:
          transmit
          drop
      889227 packets, 1097285797 bytes
      5 minute offered rate 447000 bps, drop rate 0 bps
      Match: any
what can I do???
There is still (almost) nothing matching your class. What does your configuration look like now ?
Here it is:
IntRegManzanas#sh running-config
Current configuration : 2304 bytes
version 12.4
boot-start-marker
boot-end-marker
enable password 7 1511021F0725
aaa new-model
dot11 syslog
ip cef
archive
 log config
  hidekeys
ip ssh version 2
policy-map POLICE1M
 class CLASS1M
   police cir 1000000
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
ip http server
 deny   any
snmp-server community ******* RO ELCACTI
control-plane
banner login ^C
    Acceso restringido
^C
line con 0
 password 7 040F5D51
 logging synchronous
line aux 0
line vty 0 4
 password 7 040F5D51
 logging synchronous
 transport input all
end
which IOS version are you running ? Can you post the output of 'show version' ?
Try to apply the service policy outbound on FastEthernet0/0, or as an input (instead of output) on the LAN interface...
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 17-Aug-10 05:26 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
IntRegManzanas uptime is 1 week, 2 hours, 16 minutes
System image file is "flash:c1841-advipservicesk9-mz.124-15.T14.bin"
I'll try what you're suggesting and post results.
Thanks.
