1841 bandwidth limitation (traffic shapping) not working
gasparmenendez
Level 3
Level 3
Hi folks,
I have a problem with bandwidth limitation on a Cisco 1841 Router. The thing is that I need to limit the internet bandwidth with class and policy maps in my 1841 but it's not working... when I check my Cacti (monitoring system) it shows 1841 is using more than 2 Mbps, when apparently I limited to 1 Mbps. Here's is my configuration:
Building configuration...
Current configuration : 2548 bytes
version 12.4
service password-encryption
hostname IntRegManzanas
boot-start-marker
boot-end-marker
enable secret 5 $1$r/qO$L.tQ0JnkA
enable password 7 1511021
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone MX -6
clock summer-time MX recurring
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool REDINTERNA
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 189.194.28.161 200.52.167.161
ip domain name somosggl.com
username gaspar privilege 15 password 7 094B4F1A0
username extra privilege 15 password 7 10692E3500
archive
 log config
  hidekeys
ip ssh version 2
class-map match-all CLASS1M
 match access-group name ACL1M
policy-map POLICE1M
 class CLASS1M
   police cir 1000000 bc 187500 pir 1000000
interface FastEthernet0/0
 description *** Externa ***
 ip address 10.227.225.33 255.255.252.0
 ip nat outside
 ip virtual-reassembly
 rate-limit input 1000000 187500 375000 conform-action transmit exceed-action drop
 rate-limit output 1000000 187500 375000 conform-action transmit exceed-action drop
 duplex auto
 speed auto
interface FastEthernet0/1
 description *** Interna ***
 ip nat inside
 duplex auto
 speed auto
 service-policy output POLICE1M
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.227.224.1
ip http server
no ip http secure-server
ip nat inside source list 110 interface FastEthernet0/0 overload
ip access-list standard ELCACTI
 permit 10.227.224.11
 deny   any
ip access-list extended ACL1M
 deny   ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip 192.168.1.0 0.0.0.255 any
logging 10.227.224.11
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
snmp-server community ******** RO ELCACTI
snmp-server location Canatlan
snmp-server contact Irma Mtz
control-plane
banner login ^C
    Acceso restringido
   Solo personal autorizado
^C
line con 0
 password 7 040F5D515
 logging synchronous
line aux 0
line vty 0 4
 logging synchronous
 transport input all
scheduler allocate 20000 1000
end
Can somebody help me please??
Thanks in advence. BR.
40 Replies 40
now I've got this:
IntRegManzanas#show policy-map interface FastEthernet0/1
 FastEthernet0/1
  Service-policy input: POLICE1M
    Class-map: CLASS1M (match-any)
      56691 packets, 5508977 bytes
      5 minute offered rate 39000 bps, drop rate 0 bps
      Match: access-group name ACL1M
        5 minute rate 39000 bps
      police:
          cir 1000000 bps, bc 31250 bytes
        conformed 56683 packets, 5499708 bytes; actions:
          transmit
        exceeded 8 packets, 9269 bytes; actions:
          drop
        conformed 16000 bps, exceed 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
I'll keep watching bandwidth...
That looks better. Now nothing matches the default class, which is good.
Curious to see what happens to the bandwidth utilization...
sorry, still no luck...
bandwidth goes to 2 Mbps almost.
I'll apply the service policy outbound on FastEthernet0/0 to see what happens
Thanks.
didn't work my friend, today client reached 2.74 Mbps....
what do you have configured, both the rate limiting and the service policy ?
Can you post the output of 'show policy-map interface FastEthernet0/1
hi,
 FastEthernet0/1
  Service-policy output: POLICE1M
    Class-map: CLASS1M (match-all)
      4 packets, 1368 bytes
      police:
          cir 1000000 bps, bc 8000 bytes
          pir 1000000 bps, be 31250 bytes
        conformed 4 packets, 1368 bytes; actions:
          transmit
        exceeded 0 packets, 0 bytes; actions:
          drop
        violated 0 packets, 0 bytes; actions:
          drop
        conformed 0 bps, exceed 0 bps, violate 0 bps
      3797153 packets, 3701670310 bytes
      5 minute offered rate 764000 bps, drop rate 0 bps
      Match: any
and have this configure:
policy-map POLICE1M
 class CLASS1M
   police cir 1000000 bc 8000 pir 1000000
 ip nat outside
 rate-limit input 1000000 8000 8000 conform-action transmit exceed-action drop
 rate-limit output 1000000 8000 8000 conform-action transmit exceed-action drop
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
Thanks!!
Hello
Personally i wouldn't apply CB policing and Custom rate-limiting together, I would suggest apply CB policing ingress on your rtr Lan facing interface and CB shaping egress on your wan facing interface.
This example is just matching on any traffic and limiting it to 1mb
Lan Ingress
access-list 100 permit ip any any
class-map match-any Police_cm
match ip address 100
Policy-Map Police _lan_pm
class Police_cm
police 10240000 32000conform-action transmit
exceed-action drop
Int x/x
description Lan_facing_interface
service-policy input Police _lan_pm
Wan Egress
policy-map Wan_Child
class-class default
fair queue
policy-map Wan_Parent
class-class default
shape average 1024000 128000
service-policy Wan_Child
Int x/x
description Wan_facing_interface
service-policy output Wan_Parent
res
Paul
Kind Regards
Paul
hi @Paul, I think there is an error here: match ip address 100, how it should be??
Thanks.
I have this configured:
class-map match-all Police_cm
 match access-group 100
 class class-default
  fair-queue
 class class-default
policy-map Police_lan_pm
 class Police_cm
    police 10240000 5120 conform-action transmit  exceed-action drop
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
 service-policy input Police_lan_pm
and:
but the client are still reaching 2Mbps+
thanks.
Hello
 class class-default
 class Police_cm
    police 10240000 5120 conform-action transmit  exceed-action drop  < this is 10mbp not 1mb
Note:
Shaping
1024000 128000 <  this is 1mbs
2048000 256000 <  this is 2mbs
Policing
1024000 32000  <  this is 1mbs
2048000 64000 <  this is 2mbs
Also for a better reading drop the load interval in the interface
int x/x
load interval 30
res
Paul
Kind Regards
Paul
same o same o, traffic is reaching whatever client needs....
