1841 Router Problem
mmoriarta
Community Member
I have a problem with an 1841. I get to here:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
and the router freezes up. I have enabled diagnostic mode and gotten a bunch of output. Help me please
keeleym
Level 9
Level 9
Hi There
I have seen this happen once or twice and the problem was resolved by re-seating the Flash RAm modules.
I am not saying that this is the only cause and solution. However it si worth a try as it has worked for me in the past.
If this does not work I would open a call with the Cisco TAC.
Best Regards,
Michael
I Feel you might need to rest the flash card in the router and check.
If that does not work You will have to open a TAC case.
mmoriarta
Community Member
I had to send the router back to Cisco
lol.
Some time they act crazy.
