2 bgp route-reflector
alsayed
HI
Its Possible ti cinfigure 2 bgp route-reflector in the same As?if So pl list the Situation for that..
many 10xs
Edison Ortiz
Yes, it's possible.
Route-reflector are often needed when you have multiple iBGP routers and they aren't fully meshed.
For instance, You have router 1 and 2 directly connected to router 3 in full meshed. Then you have router 4 connected to router 5 and router 6 in full meshed. Router 3 and router 4 are connected to each other. Router 3 can route-reflect in behalf of Router 1 and 2 while router 4 can route-reflect in behalf of router 5 and router 6.
HTH,
__
Edison.
This is good information.
Thanks.
Rick
10xs edy
