2 Lan 2 Wan..... problem.
erdosain99
Level 2
Level 2
Hi. I have a Cisco 2901 (2 onboard GE) and 4 interfaces ethernet module.
I have to configure 2 Wan. and two Lan. It is possible in this cisco?
When I want to configure LAN interfaces of the module I get
"May not be IP addresses configured on L2 links" ... so I understand that I can not assign an ip. How i could have two Lan working?
Greetings and thanks to all
This is a google translation.
20 Replies 20
Mark Malone
Yes that's possible
As an option for the LAN you can use vlan interfaces for each LAN subnet on the router
interface vlan 10
ip address x.x.x.x x.x.x.x
Interface vlan 20
Then assign the layer 2 ports to the vlan from your block of 4 LAN ports or create a trunk port back to a switch allowing the vlans you want
interface fe0/1
switchport access vlan 10
interface vlan 20
switchport access vlan 20
or
interface fe0/1
switchport mode trunk
The wan you can have 2 wan links on the GE interfaces they should take ip addresses no problem if there layer 3 interfaces
Then depending if your using BGP or just static default routing you could load balance the traffic or just have 1 wan link active at a time
ip route 0.0.0.0 0.0.0.0 x.x.x.x (WAN 1 )
ip route 0.0.0.0 0.0.0.0 x.x.x.x  220 (WAN 2 )
Thanks!
And if i want enable DHCP for the Lans???
How would assign to the ports?
If you want dhcp and you require to use the cisco devices rather than a server , you just create 2 scopes 1 for each vlan on the router
when the ports are assigned to the specific vlan and set as dhcp in their TCP/IP settings they will request an ip address and the router will respond with 1 from the correct pool
example need 2 of these pools
ip dhcp excluded-address 172.x.x.x  (excklude the vlan interface)
ip dhcp pool WIREDCLIENTVLAN.A
 network 172.x.x.x 255.255.255.0
 default-router 172.x.x.x (vlan interface)
 dns-server 8.8.8.8 8.8.4.4
 domain-name xxxx.com
 lease 0 2
ip dhcp pool WIREDCLIENTVLAN.B
 lease 0 2
Thank you.
The DHCP works perfect. but...
I can ping to www.cisco.com from the cisco router.
But from the pc ....... no.
This is the configuration that I have so far.
What could happen ??
This is config
! Last configuration change at 13:56:39 UTC Fri May 20 2016
version 15.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 10.0.150.1
ip dhcp excluded-address 10.0.20.1
ip dhcp pool Red150
 network 10.0.150.0 255.255.255.0
 default-router 10.0.150.1
 dns-server 192.168.1.1
 lease 0 2
ip dhcp pool Red20
 network 10.0.20.0 255.255.255.0
 default-router 10.0.20.1
 lease 0 2
ip name-server 192.168.1.1
no ipv6 cef
voice-card 0
license udi pid CISCO2901/K9 sn FTX180581WJ
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.1.11 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 switchport access vlan 150
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface Vlan1
 no ip address
interface Vlan20
 ip address 10.0.20.1 255.255.255.0
interface Vlan150
 ip address 10.0.150.1 255.255.255.0
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Your config does not include any network address translation. For a PC connected in one of your LANs with a private IP address to access the Internet then there must be NAT or PAT to translate the private address.
Rick
Rick
As Richard noted no nat no internet for internal devices , do you require assistance with that config we can provide if your stuck  ?
ip nat inside on each vlan and ip nat outside on the wan port then overload is probably required take a look at this any issues just post we can try assist
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/260-cisco-router-nat-overload.html
Ok, thats work perfect!!
A consultation ...
You can make speed control ip?
Thank you
I am glad that our suggestions about network address translation were helpful. I do not understand your question about speed control ip. Can you provide some clarification?
Rick
Rick
Hi.
I wish the Lan 1 had 1MB download and 512KB upload. And Lan 2 have only 512kb download and 252KB upload (eg.)
It's possible??
Greetings and thank you very much!
by the way, finally I'll just make use of a Wan .
You can use MQC QOS to restrict/provide bandwidth per subnet and protocol on your router , its very flexible you should be able to tweak it for what you require
The policy would be then applied to your wan interface (ISP)
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_mqc/configuration/xe-3s/qos-mqc-xe-3s-book/qos-apply.html
Example: Creating a Traffic Class
In the following example, two traffic classes are created and their match criteria are defined. For the first traffic class called class1, access control list (ACL) 101 is used as the match criterion. For the second traffic class called class2, ACL 102 is used as the match criterion. Packets are checked against the contents of these ACLs to determine if they belong to the class.
Router(config)# class-map class1
Router(config-cmap)# match access-group 101
Router(config-cmap)# exit
Router(config)# class-map class2
Router(config-cmap)# match access-group 102
Router(config-cmap)# end
Example Creating a Traffic Policy
In the following example, a traffic policy called policy1 is defined. The traffic policy contains the QoS features to be applied to two classes--class1 and class2. The match criteria for these classes were previously defined (as described in the Example Creating a Traffic Class).
For class1, the policy includes a bandwidth allocation request and a maximum packet count limit for the queue reserved for the class. For class2, the policy specifies only a bandwidth allocation request.
Router(config)# policy-map policy1
Router(config-pmap)# class class1
Router(config-pmap-c)# bandwidth 3000
Router(config-pmap-c)# queue-limit 30
Router(config-pmap-c)# exit
Router(config-pmap)# class class2
Router(config-pmap-c)# bandwidth 2000
Router(config-pmap-c)# end
Example: Attaching a Traffic Policy to an Interface
The following example shows how to attach an existing traffic policy to an interface. After you define a traffic policy with the policy-map command, you can attach it to one or more interfaces by using the service-policy command in interface configuration mode. Although you can assign the same traffic policy to multiple interfaces, each interface can have only one traffic policy attached in the input direction and only one traffic policy attached in the output direction.
Router(config)# interface fastethernet 1/1/1
Router(config-if)# service-policy output policy1
Router(config-if)# exit
Router(config)# interface fastethernet 1/0/0
Router(config-if)# end
Hi.
OK thank you very much.
I want the ip delivered by dhcp. have a lower bandwidth. It's possible?
That static ip have the bandwidth, corresponding to Lan. And the dhcp have a value less bandwidth.
thanks!
I know that the translation is bad, I hope to be understood.
I don't really understand that are you saying you want to restrict DHCP broadcast traffic ?
Could you not just assign users longer leases to reduce the traffic if there moving around the network a lot and constantly requesting address from the server
I have never seen qos used to do that with dhcp , ftp an other intensive bandwidth resource protocols yes definitely
really dhcp should not be using so much bandwidth that you need to restrict it
Thanks!
Hi. No. What I want is to reduce the bandwidth of machines with ip by dhcp.
I want the machines with ip by dhcp, have less bandwidth than those with static ip.
For example, the pc with ip by dhcp can not exceed 512kb bandwidth.
Thanks again! (and sorry, i can understand, but cannot write)
yes that's possible but you would either need to know the full subnet for the DHCP users and match the class-map with an acl against them and then set their bandwidth to be 512kb
so like the example above your DHCP users say would be using acl 101 that would be there subnet , they would be class1 so where bandwidth 3000 is you would change that to 512 or 512000 depending what the platform is using , use the question mark ? after the bandwidth statement to check , you can then police either if required
