05-19-2016 06:36 AM - edited 03-08-2019 05:50 AM
Hi. I have a Cisco 2901 (2 onboard GE) and 4 interfaces ethernet module.
I have to configure 2 Wan. and two Lan. It is possible in this cisco?
When I want to configure LAN interfaces of the module I get
"May not be IP addresses configured on L2 links" ... so I understand that I can not assign an ip. How i could have two Lan working?
Greetings and thanks to all
This is a google translation.
06-07-2016 05:48 AM
Hi...... sorry but... i dont know how to "know the full subnet for DHCP"...
DHCP goes from 10.0.150.153 to 10.0.150.254
and 192.168.9.153 to 10.0.150.254
but i dont know how to do a access list for the range.... what would be the syntax??
Thanks!
06-07-2016 06:03 AM
The scope you have in the original post is a /24 class C , I don't see any scope set for a 192 range
access-list 176 permit ip 10.0.150.0 0.0.0.255 any
Then under your class-map you would set the acl
class-map class1
match access-group 176
ip dhcp pool Red150
network 10.0.150.0 255.255.255.0
default-router 10.0.150.1
dns-server 192.168.1.1
lease 0 2
06-08-2016 07:18 AM
but i want a acl just for the DHCP... to put that acl in the class-map...
Remember that just want to control the bandwidth in the IP delivered by the dhcp.
This is the config...
! Last configuration change at 17:49:07 UTC Mon Jun 6 2016
version 15.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 10.0.150.1 10.0.150.153
ip dhcp excluded-address 192.168.9.1 192.168.9.153
ip dhcp pool Red150
lease 0 2
ip dhcp pool Red9
network 192.168.9.0 255.255.255.0
default-router 192.168.9.1
lease 0 2
ip name-server 192.168.1.1
no ipv6 cef
voice-card 0
license udi pid CISCO2901/K9 sn FTX180581WJ
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.1.11 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.9.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1/0
switchport access vlan 150
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface Vlan1
no ip address
interface Vlan150
ip address 10.0.150.1 255.255.255.0
ip nat inside
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 109 interface GigabitEthernet0/0 overload
ip nat inside source list 150 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 109 remark ==Red9==
access-list 109 permit ip 192.168.9.0 0.0.0.255 any
access-list 110 remark ==DHCP-Red9==
access-list 150 remark ==Red 150==
access-list 150 permit ip 10.0.150.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
THANKS!!
05-19-2016 07:52 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A couple of notes:
Often L2 interfaces for routing, on ISRs, don't offer all the same features as a L3 interface port.
L2 interfaces, on ISRs, might not offer the same performance of the built-in ports.
(BTW, often ISRs can obtain add additional L3 ports, as modules.)
05-19-2016 12:31 PM
but is posible enable dhcp for each Lan??
05-20-2016 06:28 AM
Hello
Just like to add marks excellent post, that if you do use floating default static addressing be aware that if you lost connectivity somewhere off the WAN1 network, you may get a blackhole senario as to when your router still thinks that it primary next hop is valid which it may well be but the some outage is occurring elsewhere.
I would suggest apply some IP SLA tracking towards an remote ip available via WAN1 network sourcing from your WAN1 Lan connection, then if that become unavailable your primary default static will be removed from router routing table and the secondary default will be used.
Example:
ip sla 10
icmp-echo (remote wan1 ip) source-ip vlan 10 svi ip
frequency 5
ip sla schedule 10 life forever start-time now
track 10 rtr 10 reachability
Ip route 0.0.0.0 0.0.0.0 <WAN1 nexthop ip> track 10
ip route 0.0.0.0 0.0.0.0 <WAN2 nexthop ip> 220
res
Paul
