2800 router with 4 port switch card
jasosan22
Is it possible to do port mirroring on a 2800 router that has a 4 fe switchport in the WIC? I need to monitor the f0/1 port on the router.
Yudong Wu
Level 7
Level 7
Nope. It does not support SPAN.
Richard Burts
Jason
While you can mirror a switch port on another switch port, but it is not supported to mirror a router port on the switch port. So I believe that the answer to your question is that no you can not do this.
Rick
Rick
