2801 multiple adsl pppoe trunk to switch
danletkeman
I have four ADSL lines and I want to setup my 2801 to do pbr according to source ip. I have 4 linux routers doing the pppoe to our isp but I would like to have the 2801 doing the pppoe and the pbr to eliminate the linux routers. Can I trunk from the 2801 to a 2960 switch configure 4 vlans plug in the adsl modems directly to the switch and have the 2801 doing the pppoe? Or do I have to have an hwic-4esw?
If this is possible how would I configure the pppoe connections?
I have the trunk working as well as the pbr config working.
Dan.
drolemc
Level 6
Level 6
The following document shows how to configure a Cisco 1700 using the Ethernet WAN Interface Card (WIC-1ENET) to act as a Point-to-Point Protocol over Ethernet (PPPoE) client with Network Address Translation (NAT).
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093fbf.shtml
