HSRP and VRRP Question
haithamnofal
Level 3
Level 3
Is there any limitation to the number of routers which I can configure in an HSRP or VRRP group? How many can I configure in one group and do redundancy between?
Haitham
ankbhasi
Hi Haitham,
As far as HSRP is concerned I do not think there is any limitation on the number of routers in same group. Not very sure for VRRP.
You can have as many routers in one group as you want, but only two will be sending out HSRP hellos to the HSRP multicast address (the active and standby routers). All other 'inactive' routers in the standby group will LISTEN to the hellos but will not be sending. As soon as the other 'inactive' routers hear only one hello (when either the active or standby goes down) the 'inactive' router with the highest priority becomes the new standby (because if the active router goes down the previous standby becomes active and the inactive router becomes the standby or if the previous standby goes down the inactive router becomes the standby). Either way, the inactive router in the standby group with the highest priority becomes the standby router.
Ankur
*Pls rate all helpfull post
in addition to the Ankur post;
for HSRP this can also be platform specific as well as the Technology; e.g like 6509 w/ Sup2/PFC2/MSFC2 max. groups is 16 while all others Sups is 256.
Thanks.
